Endmill/Insert Question
TCMT-32.52 TTM
3 insert holder has been noted on package
TCMM-32.52 THM
plastic, alum' & cast iron was noted on package @ the time. More recently DO NOT USE has been added.
Both insert styles are uncoated.
Widia is moulded into the insert package w/ a Tyson Tool label affixed.
Since I set up my shop I've used the two endmills, but haven't been entirely satisfied w/ the results (so so surface finish). I don't recall an issue when I was using them @ work (on a Bridgeport larger than my 9 x 49). I've tried contacting Tyson & Widia but they weren't able to help me.
Just curious if anyone can comment on what I have and any suugestions to improve my results?
Re: Endmill/Insert Question
THM: 'Main grade for milling short-chipping ferrous materials, nonferrous metals, and alloys as well as plastics. Very good edge strength and sharpness.'
TTM: 'Grade with balanced wear-resistance and toughness properties for medium duty steel machining operations.'
Thanks. That confirms what was noted. At the time I wasn't sure who added the note, whether it was the vendor or our supervisor (an electrician, don't ask).Glenn Wegman wrote:THM: 'Main grade for milling short-chipping ferrous materials, nonferrous metals, and alloys as well as plastics. Very good edge strength and sharpness.'
BTW I just noticed, in the TCMM package there is 1 coated insert. I guess that's the reason for the "gold -> steel" notation on the package.
