Hi there, I have had my Grizzy G3102 for many years, and the other day the switch burned up, so I found out the extra switch that came with the unit is for running it on 220v. Duh, Why didnt I catch this years ago? Anyway, can someone out there assist with what wiring changes I need to make to flip this to use the 220 v switch and wire it all up for 220v?
Thanks in advance!
Grizzly G3102 How to convert to 220V?
Re: Grizzly G3102 How to convert to 220V?
I got your PM and will make a copy of my wiring diagram and email it to you per my reply in he PM.
Dave C.
Dave C.
Awesome, Thanks!
I had the points burn up on my mill and since they had sent another complete unit in 220vac with the mill I just swapped out the coil and was good to go with out having to rewire. But next time that may be the answer.
