Bridgeport Power Feed
I came across one of these this week....didnt realize Bridgeport made these in the past. Anyone have one of these? Good experience? Bad experience? I would rather buy one of these used than the current China made ones I see sold thru most outlets.....unless I hear otherwise. Thanks for input.
- SteveHGraham
Re: Bridgeport Power Feed
This won't be helpful to you, but I like the speed gradation. I always wondered how I was supposed to figure out my x speed. Maybe I can find a way to create a gradation for my Asian feed.
I have one on one of my BP's works fine . BUT will not bolt up directly like the Servo clones ,lead screw is shorter. Going the other way replacing that with a Servo style you can get a lead screw extension kit.
John
John
www.chaski.com
"Anyone have one of these? Good experience? Bad experience?"
Mine was made mid 80's. Good experience so far.
I have heard once you have trouble, they're done.
Snagged a Servo from a friend who went CNC so I have a backup.
Not hard to calibrate with a scale and a stopwatch.
I recall they are not closely repeatable, but fine for B'port style work.
Not necessarily true. The board in mine failed years ago, but I was able to make an exchange for one that had been serviced. Unfortunately, the company involved is no longer (Seattle, Washington). I seem to recall it cost me about $100. Worth the expenditure, for sure.Carm wrote: I have heard once you have trouble, they're done.
I've been well satisfied with mine.
Steve---speed is selected based on performance. If you don't have a clue where to start, start slow and increase until you achieve the cut you desire.
Edited to make clear what failed.
I have the very early power feed, it works, but I am not buying another vfd just to use it. I am more concerned about the weight of it causing table sag. I leave my Bridgeport with the power feed cranked close to the knee.
No harm in doing so, but the idea of the feed causing sag is unfounded. The tensile strength of cast iron exceeds by an unfathomable margin, the weight of the drive.WJH wrote:I am more concerned about the weight of it causing table sag. I leave my Bridgeport with the power feed cranked close to the knee.
Bridgeport tables sag because of internal stresses, not because of weight. Because the top surface is fully machined, unlike the bottom surface, it releases stresses more than the bottom of the table, thus the eventual bowing. If the castings were properly aged or heat treated, it wouldn't be an issue. Considering the relatively low price of a Bridgeport (they are not a great machine), that's expecting far more than money can buy.
I think the "sag" is caused by the unequal weight in this case. It is more wear to the right side than the left. It appears as sag in a conversation but is the weight of the earliest gear shift power feeds. Even I don't think cast iron "sags". I was disabused of that notion long ago.
This gets into another truth you mentioned about the table curing at a different rate and changing by the production milling done on the top compared to the bottom. The effect to the table surface by a heavier table feed unit, would balance it out if it was equal at both sides but it isn't.
I deleted before posting anything about tying one generated motor phase to another because I cannot edit or delete.
Going back to John Evans comment....these units are not a direct bolt in place unit. I see that now. You actually have to change the lead screw. So there is a hidden cost involved with this that looks to be about $200 to $300 additional to do that. So I will need to rethink if I want to go thru all that effort as much as I would love to have a unit that says "Bridgeport" on it....
