Page 1 of 2
Enco 91007
Posted: Wed Feb 15, 2017 12:52 pm
by vintageracer13
Hello All,
I am looking for any info I can find on the Enco 91007. I found a 1983 in the back of a barn that I want to repair. The man that owned it took the quill and spindle out. He has since passed away so I don't know what the issue was. I suspect the gear that moves the quill up and down is bad. By the lack of info I have found so far I know this whole project will be a long shot but the price is low enough to make it worth pursuing. Thanks in advance for any help you all can provide
Re: Enco 91007
Posted: Wed Feb 15, 2017 10:38 pm
by John Evans
A picture or 2 of the machine in question would help.Expect to make any needed parts.If this is a drill/mill type machine it better be free!
EDIT : Just googled it ,typical drill/mill . You will be making parts most likely ,max value maybe $50.
Re: Enco 91007
Posted: Thu Feb 16, 2017 2:10 am
by Harold_V
I'm going to assume this is a round column Enco mill/drill, so my comments will be flavored accordingly.
Because parts are most likely not available, even $50 is unreasonable. I'd hesitate if it was free, as making a quill and spindle assembly that would serve is likely far beyond the skill level of most folks, and would require a substantial sized lathe as well. You'd be far better off to put the money you're willing to spend towards a different machine, which will give you the opportunity to avoid a round column.
The inconvenience of owning the round column often escapes those who have no machining experience, so it may not seem significant to you. You'll be well served to pay attention, however. They are the source of considerable aggravation.
Re: Enco 91007
Posted: Thu Feb 16, 2017 6:52 am
by vintageracer13
Thank you for your input. I currently own a RF-31 so I am aware of the challenges. A knee mill just doesn't make sense with the footprint I have to work with. The quill itself looks fine but the gear needs attention I think.
Re: Enco 91007
Posted: Thu Feb 16, 2017 11:30 am
by ctwo
If you have an RF-31, what is the difference in what you are looking at? I am a little surprised at the value being presented, but I am assuming the mill you are looking at is another version of your RF-31.
I think mine is an Enco as well, but I do not recall seeing any branding on it. I think it is the largest of the benchtop machines like this, and a worthy machine to have. But not two versions of the same. Mine is on its own stand and takes up as much floor space as a medium size knee mill.
If the quill pinion is chewed up, repair might not be out of the question. It may also just be with the fine feed.
Re: Enco 91007
Posted: Thu Feb 16, 2017 2:33 pm
by vintageracer13
I am sorry mine is a 30 not a 31. The one I am looking at has a large steel base so I don't know if I would clasify it as bench top. This is a 91007 without the large base
Re: Enco 91007
Posted: Thu Feb 16, 2017 3:54 pm
by Harold_V
vintageracer13 wrote:Thank you for your input. I currently own a RF-31 so I am aware of the challenges. A knee mill just doesn't make sense with the footprint I have to work with. The quill itself looks fine but the gear needs attention I think.
Ahhh! That's very different. I had interpreted your first post as the quill and spindle having gone missing. I retract my comment in regards to value.
Mill drills are somewhat a compromise as mills go, but they are an excellent drill press.
Re: Enco 91007
Posted: Thu Feb 16, 2017 5:35 pm
by spro
The pic of the 91007 looks like a newer version of my M/D. Mine has the 4" column and the head is raised by a crank at the left side of the Head. That's Really awkward. The column base is octagonal, 2hp single phase motor, 28 3/4" x 8 1/4" table. I still use it in the limitations of my basement.
Re: Enco 91007
Posted: Thu Feb 16, 2017 7:26 pm
by SteveHGraham
Maybe it would make sense to try to find sister machines made by other manufacturers, so when you look for parts, you won't be restricted to Enco machinery.
I would tell the owner to give me the machine with the understanding that if I can get it to work within, say, three months, I'll give him $50. If not, his payment is your willingness to get a piece of junk off his property.
Re: Enco 91007
Posted: Fri Feb 17, 2017 7:09 am
by vintageracer13
spro wrote:The pic of the 91007 looks like a newer version of my M/D. Mine has the 4" column and the head is raised by a crank at the left side of the Head. That's Really awkward. The column base is octagonal, 2hp single phase motor, 28 3/4" x 8 1/4" table. I still use it in the limitations of my basement.
What is an M/D? I have never heard of these
Re: Enco 91007
Posted: Fri Feb 17, 2017 10:53 am
by ctwo
The machine has done lots of good work for me even though it is a little limber. I was fortunate in having found it with a 3-axis DRO and power feeds, including one on the head!!! That's not awkward at all, spro.
Re: Enco 91007
Posted: Fri Feb 17, 2017 12:58 pm
by Gary Armitstead
I have a 91000 Enco mill/drill that's 36 years old and I built my Gene Allen ten-wheeler using this mill. NO....it's not a professional machine, but I'm a retired die sinker and tool maker (40 years) and this mill has done everything I have asked of it, including the "fussy" stuff like connecting rods for my my ten-wheeler. Dialed right in, not a problem. You have to know the capacity of these mills and not do more than they are designed for. A good machinist should be able to do fine work with these little mills. You just have to know how
Mine even has the original belts on the drive!
