Milling Machine spindle
Moderators: Harold_V, GlennW
spro
Re: Milling Machine spindle
Post by spro » Fri Apr 28, 2017 11:52 pm
The "C" meant "Cherrying" and I thought "H" meant "Hi Speed". My notes say the "C" use Bridgeport B3 collets.
SteveM
Post by SteveM » Sat Apr 29, 2017 1:12 pm
spro wrote:The "C" meant "Cherrying" and I thought "H" meant "Hi Speed". My notes say the "C" use Bridgeport B3 collets.
C was the original milling head. No quill.
M was the first head with a moving quill
J is the head we all recognize as a Bridgeport head, although it came in several models
R is a heavy-duty head - think of a J without the quill.
T is the cherrying head
E is the slotting head
You can read on Bridgeport heads here:
http://www.lathes.co.uk/bridgeport/page2.html
spro
Post by spro » Sat Apr 29, 2017 4:59 pm
Good info. I haven't owned the "C", "H" or "T" heads. A little more fuzzy about them. One thing is collets. The Bridgeport B3 ( for C and some M heads) are sort of expensive. Then the Hardinge 2VB collets for others are really expensive.
