New boring and facing head
Well an "i suck" gloat
Took a chance in a boring head for a great price. From the ad it appeared incomplete. Luckily a bad pic and a great deal. Not a light piece of tooling. The head itself is around 50lbs. Next to fit it to my mill to see if I have to make a new collar.
Re: New boring and facing head
What type of mill do you have that will accept that?
40 taper
abene or my SWI knee mill
- SteveHGraham
I was waiting for someone to ask.GlennW wrote:What type of mill do you have that will accept that?
Abene
SWI
SWI
- SteveHGraham
What is that big grey flat thing under those excellent machines?
I wondered that, too. I think I've seen them before, and thought I should get one, too. Or maybe I already have one. Haven't seen it in awhile if I do.SteveHGraham wrote:What is that big grey flat thing under those excellent machines?
Clean huh? Nice to see the floor in the new space
Very cool. That must be the "W" you mentioned. Obviously it is suspended at the head and boring is either manual or automatic advance with trip points. I think that unit cost new, about what new mill does now.
50 lbs hanging on the quill might get interesting!
the unit is not spinning, it is secured to the quill via direct bolt or compression sleeve. only the internals are moving via the taper. That way you can still use the handle/crank etc.
