Hello dears
I have a vertical milling machine, but unfortunately its gearbox is out of work.
I need its manual or detailed map to repair it. Can you please help me in this topic?
I will be thankful
Adcock shipley vertical milling machine
Re: Adcock shipley vertical milling machine
You can find some information about A&S mills here:
http://www.lathes.co.uk/adcock&shipleyv ... index.html
Can you give a more detailed description of what is up with the gearbox?
Pictures would be good.
Also, please update your profile with your location. You never know: help might be right around the corner.
"out of work" meant "out of whack" btw.
