bridgeport handwheel clutch collar - ball stuck
Moderators: Harold_V, GlennW
dly31
Re: bridgeport handwheel clutch collar - ball stuck
Post by dly31 » Tue Dec 26, 2017 10:43 pm
I have had good results removing such stuck balls and broken dogbones where there seemed to be burrs by sticking a small tube to the ball, putting valve grinding compound into the hole, and gently pulling on the tube while rotating it to grind the burrs away.
Don Young
