Cugir FU32 vretical milling machine
Moderators: Harold_V, GlennW
miller
Post by miller » Sun Oct 29, 2017 10:27 pm
I have purchased a Romanian built Cugir FU32 milling machine that was built around 1980. It seems to have a few gremlins mainly with the travel direction of the table. Sometimes the table will only work in one direction in all axis. If you manually push the solenoid for both directions things return to normal. Does anyone know where I can get a copy of a manual for this machine. It is a great machine when it works correctly
