Page 4 of 4
Re: Brown & Sharp N0. 1 Milling Machine
Posted: Sun Jan 07, 2018 8:28 pm
by spro
Well it came to its new home intact. Congratulations. The machine appears in remarkably good condition for its age. Where to begin, unraveling this puzzle of tooling and attachments. I see many which are directly used and other arbors which need figuring. I can see a semi- universal vertical head is there and even arbor or collets for it. The way the OA is now, there was probably an independent motor driven head attached to that plate. There are parts of your dividing head or some other.
Posted: Sun Jan 07, 2018 8:47 pm
by H&NERY
I didn't have much time to study it over today, right now I am storing it at the shop where I work until I make some space for it in my home shop. But, where I have it now makes it easier for me to clean it up and inspect things over a little bit. Now I need to figure out just where I am going to put it in my shop and what to power it with.
Posted: Wed Jan 10, 2018 10:27 pm
by H&NERY
Here is a few more pictures, I found some collets in the storage compartment. I also took the homemade bracket off the end of the ram and slid the vertical head on the ram.
Posted: Thu Jan 11, 2018 12:42 am
by spro
All Right. The brass split- sleeve inside the OA mount of the head, is eccentric. You tune it to be concentric to the drive arbor. I don't see that drive arbor yet. It will be B&S #10 or close and fits inside the head with a long key slot. That way, the head and OA are shifted out as needed.
Posted: Fri Jan 12, 2018 10:39 am
by RONALD
Here are three photos of the vertical heads on my three mills.
Each one is more robust, and able to run at higher RPM, the last on the 1950's #2 can be run at over 3000 RPM.
Posted: Sat Jan 13, 2018 11:52 pm
by spro
Thanks for your pix and they are great to this topic! We can see M&N's vertical head of his earlier mill. I can see the transition over decades. Man they did a lot. Eye candy in a machine way.
Posted: Sun Jan 14, 2018 11:15 pm
by H&NERY
Does anyone have a good picture of what the original dividing head would look like and what all went with it. I have some dividing plates and change gears which I believe were part of the dividing head.
Posted: Tue Jan 16, 2018 9:44 am
by RONALD
Brown & Sharpe offered a variety of dividing heads, the one they supplied with their universal mills came with a whole set of gears to allow the cuttings of spirals and other shapes.
Lots of B&S parts were offered on eBay when I did the rebuild shown below, today only B&S measuring devices appear on eBay.
I'm still looking for a #0 Slotter for that mill; kinda rare.
https://www.youtube.com/watch?v=C-sfBZWdyPA
Posted: Tue Apr 03, 2018 7:45 am
by H&NERY
So I picked up this B&S Universal Dividing Head the other day, the price was right so I couldn't turn it down, I know its not the correct one for my mill but I do believe I can make it work. It came with a full set of gears also. The gears for the original dividing head had finer teeth on them and the center hole bore of the gears are 7/8 of an inch where these are 1". I think I can manufacture an adapter to bump the 7/8' shaft on the mill up to 1".
