Offshore turret riser for Bridgeport
Moderators: Harold_V, GlennW
Mark 2
Post by Mark 2 » Tue Jan 01, 2019 10:15 pm
I'm wanting a turret riser for my '72 Bridgeport and am wondering if a less expensive import will fit the Bridgeport. Specifically I'm seeing anew Acer on Ebay for $275 shipped. Does anyone know if it will fit. The company selling it is vague on what should be a simple answer.
Re: Offshore turret riser for Bridgeport
Post by SteveM » Wed Jan 02, 2019 12:52 pm
Look for a used one on craigslist or ebay (with a location limitation). That may be your best bet to get one that actually fits.
I see them periodically for cheap (but then, I'm here and you're there, so your mileage may differ).
John Evans
Post by John Evans » Wed Jan 02, 2019 2:40 pm
Maybe!! From personal experience one from a Webb will not with out some lathe work ,ditto a BP one won't work on a Sharp.
www.chaski.com
pete
Post by pete » Wed Jan 02, 2019 6:33 pm
Since you want something to fit what you already have then pulling the motor, head and then the ram and then removing the top turret cap on the column would get you access for some accurate measurements for the bolt pitch, size, cap diameter and column hole diameter. Without those there's no real way for any supplier of those risers to say if it will or won't fit. Yeah it's going to take an hr or two to re/re everything, but I don't see where you have much choice. If you've never done it before then reach through whatever access opening is in either the rear or side of the column and hand support the internal spider the turret's bolts tighten to while your removing the last bolt.
Mark 2
Post by Mark 2 » Wed Jan 02, 2019 6:42 pm
Pete,
Yeah that's the best solution. I've done it all before when moving the machine but of course I didn't take dimensions. I was hoping that this issue was common enough that there would be more folks on the board that could say yay or nay definitively. The bolt hole dimensions are fairly easy but the bore on the BP for the turret is as important and more difficult to establish without removal and I'd rather not do that until I had a riser in hand to put it in place.
Thanks for the input, Dave
pete
Post by pete » Wed Jan 02, 2019 7:09 pm
Yeah I'd sort of thought about having to duplicate the work twice while I was typing that out. It sucks but I'm not sure just how much even Bridgeport themselves made dimensional changes to the design over the years. Measuring is probably the only sure way. I have no immediate plans for adding a riser to my BP clone but do have to move mine shortly. Think I'll grab those numbers myself while I'm at it just in case. I've seen a couple of threads on the PM forums asking the same question you have, but even there no one could provide a 100% yes / no what is a direct fit between after market risers for other machines and OEM Bridgeport parts.
Mark 2
Post by Mark 2 » Wed Jan 02, 2019 9:47 pm
Pete,
This is good information, not the answer that I would have wanted but it'll save me time trying to get an answer that isn't readily available. I'm simply going to have to pull the darn thing apart to measure it. It's going to be busy for a while so it'll have to wait.
Thanks! Dave
TimTheGrim
Post by TimTheGrim » Thu Jan 03, 2019 2:09 pm
Just throwing thus in as a point of reference...
I used this one in the 4” model.
https://www.wttool.com/index/page/categ ... _id/16699/
My mill is a Birmingham built in 1996 with a Taiwan head and China base.
Fit is perfect, tram is smooth. 100% satisfied.
I worked in a shop that had a Birmingham Taiwan head on a genuine BP base.
I’m 99% sure this would fit a ‘72 BP.
Did the swap in one afternoon with my HF foldable engine hoist.
Illigitimi non Carborundum
'96 Birmingham mill, Enco 13x40 GH and Craftsman 6x18 lathes, Reid 2C surface grinder. Duro Bandsaw and lots of tooling from 30+ years in the trade. Now I boil oil.
Mark 2
Post by Mark 2 » Thu Jan 03, 2019 9:01 pm
Well, now you've got my interest! Thanks
chet86
Post by chet86 » Thu Jan 03, 2019 10:58 pm
I have a Bridgeport 6" riser for $200.00 plus shipping.
Mark 2
Post by Mark 2 » Thu Jan 03, 2019 11:05 pm
Did the riser come off a Bridgeport? Do you have bolts for it? What is the cost of shipping to 98292?
Thanks, Dave
chet86
Post by chet86 » Thu Jan 03, 2019 11:06 pm
Yes it came off a BP Shipping cost ????
