What is this CAT40 tool?
Moderators: Harold_V, GlennW
Rex
Post by Rex » Mon Jan 21, 2019 8:23 pm
I got this in a batch of other pieces. I'm trying to figure out what it is.
It sort of looks like a flycutter, but not like any I've seen. The two set screws are an inch apart and oppose the large threaded hole at either side, as though they are to adjust the cant of something as it pivots on the larger screw.
Any ideas?
choprboy
Re: What is this CAT40 tool?
Post by choprboy » Mon Jan 21, 2019 10:42 pm
Basing on what I have plans to make out of a morse taper stub... someone's custom spade drill bit holder? The screws being the alignment pins and the large hole for a set screw to lock it in place?
Rex
Post by Rex » Mon Jan 21, 2019 11:43 pm
Interesting thought.
It would drill a shallow hole, at best
Ianagos
Post by Ianagos » Wed Jan 23, 2019 12:44 am
Looks to me like a nmtb 40 or nt 40 definitely not cat 40.
But the big hole is just there because someone made that flycutter holder from a regular endmill holder it seems. They are cheap and you could easily make a rigid flycutter from it.
Rex
Post by Rex » Wed Jan 23, 2019 7:41 am
I knew it was 40 taper, but I don't know how to tell them apart.
I don't use it.
I had not thought about it being a modified endmill holder. I'll take another look.
Still though, the two grub screws are very small for the size cutter this seems intended to use.
earlgo
Post by earlgo » Wed Jan 23, 2019 3:23 pm
A NMTB 40 shank always has a driver slot in the collar.
Here is a picture of the fly cutter that I have for the Producto horizontal mill. easily seen is the driving slot that fits over the lug on the spindle socket. I think my dad may have made the actual cutter holder not the 40NMTB tool holder. This works very well.
40NMTB fly cutter
--earlgo
Rex
Post by Rex » Wed Jan 23, 2019 4:26 pm
Earlgo, that is something I've not seen before.
I can see where this tool may be part of such.
And I guess that make it a NT40?
earlgo
Post by earlgo » Wed Jan 23, 2019 5:03 pm
Rex, here is a pic of the #40NMTB R8 collet adapter I use in this mill. Again one can see the driving lugs for the tool holder.
--earlgo
Ianagos
Post by Ianagos » Wed Jan 23, 2019 5:28 pm
earlgo wrote:Rex, here is a pic of the #40NMTB R8 collet adapter I use in this mill. Again one can see the driving lugs for the tool holder.
--earlgo
I have a nmtb 40 with no drive lugs. My mill also has no drive keys.
pete
Post by pete » Wed Jan 23, 2019 7:23 pm
Not that I know much about 40 taper tooling, but I suspect that wasn't made from an end mill holder. The set screws are in the incorrect orientation and spaced too widely for any end mill holder. Unfortunately I've never seen a tool holder like it. The horizontal set screws make the fly cutter guess logical, that large threaded cross hole is for ???????
Ianagos
Post by Ianagos » Wed Jan 23, 2019 8:03 pm
pete wrote:Not that I know much about 40 taper tooling, but I suspect that wasn't made from an end mill holder. The set screws are in the incorrect orientation and spaced too widely for any end mill holder. Unfortunately I've never seen a tool holder like it. The horizontal set screws make the fly cutter guess logical, that large threaded cross hole is for ???????
The large threaded cross hole looks like the original set screw for an endmill holder then someone took it cut a slot in it and added the two small set screws to make it a flycutter. I noticed there was no screw in the hole in the picture therefore why I think it wasn’t needed.
Coulda been a shop made holder that wasn’t all that great and someone made it into a fly cutter holder where runout is not as important.
Rex
Post by Rex » Wed Jan 23, 2019 9:14 pm
I would think an endmill holder with an OD that large would have a fairly large hole for the endmill. Certainly bigger than the 1/2" slot.
