Bridgeport as a drill press
Moderators: Harold_V, GlennW
Post by SteveM » Thu Mar 14, 2019 9:05 pm
A friend owns a steel company and is looking for something to drill holes in steel.
While They have large structural stuff on which it would be more appropriate to use a magnetic drill, we have a Bridgeport for sale locally that has some rust on it and needs a good cleaning. Even if the accuracy is compromised by a couple of thou, that's probably fine for what he does.
It goes down to 80 rpm in back gear, and if I remember, the J head has a downfeed, so he could run it without having to babysit it. I looked up some speeds for large hole saws and at 80 rpm in mild steel you could run a 3" hole saw.
Would this be an appropriate machine for his use?
thunderskunk
Re: Bridgeport as a drill press
Post by thunderskunk » Thu Mar 14, 2019 11:37 pm
I’m not sure I wouldn’t baby sit it...
"We'll cross that bridge once we realize nobody ever built one."
pete
Post by pete » Thu Mar 14, 2019 11:47 pm
You aren't supposed to use those head feeds for much over a 3/8ths drill size. The internals aren't built for that use and those feeds are really only meant for single point boring. Apparently even drilling one hole too large and some of the internal gearing will shear there teeth off in the drive.
Post by Harold_V » Fri Mar 15, 2019 1:53 am
What Pete said. A BP is a poor compromise for a drill press unless small drills are involved. One of the (very real) problems is how do you grip the drills? Large drills typically have tapered shanks.
My recommendation? Tell him to explore radial drill presses. They're built to drill large holes and are powered accordingly.
Post by SteveM » Fri Mar 15, 2019 8:26 am
OK, thanks guys.
Oh, and if anyone wants to buy this Bridgeport, contact me via PM.
It's located near Bridgeport (yes, it hasn't traveled very far from the place of its birth).
We are still working on prices (I'm helping to liquidate a machine shop).
whateg0
Post by whateg0 » Fri Mar 15, 2019 9:04 am
OK, thanks guys.
Man! Trying to sell a rusty bridgeport after the discussion about the rusty lathe a few days ago? LOL I wish it was closer. I'd like to have one.
Dave
Post by SteveHGraham » Fri Mar 15, 2019 10:23 am
Meanwhile, for the home shop, it would be a killer drill press. And not much fun to move.
discodan
Post by discodan » Fri Mar 15, 2019 12:56 pm
I've seen at least two BP heads made into drill presses posted on Craigslist over the years. Not sure how well it works out though.
ERIE S-1 BERKSHIRES
Post by ERIE S-1 BERKSHIRES » Fri Mar 15, 2019 9:53 pm
That's not necessarily true about the innards being for 3/8 holes only my friend wood regularly drills with a carbide tipped drill 3/4" cast iron buns 7/8 stainless steel bongs by the thousands and no pilot hole and still going strong
Post by spro » Fri Mar 15, 2019 10:40 pm
The Bridgeport M head with the MT#2 taper is fine.
Post by Harold_V » Sat Mar 16, 2019 3:25 am
Not according to the factory manual. It distinctly mentions that power feed should not be used beyond 3/8" diameter for drilling. If your friend is hand feeding, that's not an issue.
Richard_W
Post by Richard_W » Sat Mar 16, 2019 1:12 pm
OK, thanks guys.
If you are helping to sell a machine shop, then have them buy a radial drill press if the shop has one available.
Richard W
