Machinist Jacks
Moderators: Harold_V, GlennW
RSG
Re: Machinist Jacks
Post by RSG » Wed May 15, 2019 6:45 am
Machinist Jacks don't have to be big, nor made of steel (cast or otherwise). I made a few of these for supporting delicate parts that hung out of the end of my rotary table when I was doing making some cuts on the top of the part. This one in particular has a thrust bearing under the top plate so I can dial it up with my fingers without it shifting.
Re: Machinist Jacks
Post by SteveM » Wed May 15, 2019 11:09 am
Thanks. You've just added something else to the list of projects I need to do because I just HAVE to have some of those.
Re: Machinist Jacks
Post by BadDog » Wed May 15, 2019 11:41 am
Very nice
RSG
Re: Machinist Jacks
Post by RSG » Wed May 15, 2019 2:33 pm
LOL@ Steve!
pete
Re: Machinist Jacks
Post by pete » Wed May 15, 2019 7:24 pm
Make that two of us need/wanting to build some of those. :-) The thrust bearing is a nice touch and great idea.
mcostello
Re: Machinist Jacks
Post by mcostello » Wed May 15, 2019 8:11 pm
Have one? Better make a pair. The money is all in the first part.
earlgo
Re: Machinist Jacks
Post by earlgo » Fri May 17, 2019 9:04 am
RSG and/or Steve:
Looks like you have hit on a cottage industry.
Send a cut sheet when you get it off the ground. I'd be interested.
--earlgo
