Vise Identification
Moderators: Harold_V, GlennW
germaneighter
Vise Identification
Post by germaneighter » Thu May 23, 2019 1:23 pm
Anyone know the maker of this 6" vise? thanks
Re: Vise Identification
Post by Bill Shields » Thu May 23, 2019 10:00 pm
I have one very similar - maybe a Bridgeport
ERIE S-1 BERKSHIRES
Post by ERIE S-1 BERKSHIRES » Fri May 24, 2019 3:39 pm
Bill Shields is correct that is a Bridgeport I have three of them,
germaneighter
Post by germaneighter » Fri May 24, 2019 4:47 pm
Thanks, I thought it probably was. I looked it over close last night and there is no branding anywhere that I can see.
Post by spro » Fri May 24, 2019 7:53 pm
It looked like a Bridgeport to me also. It has the trough type base which probably channeled the cutting fluid into the outside rim of the table. That way, it was recycled instead of clogging the T slots. Also has the feature of outer jaws. There may be evidence of small holes at the side, where the emblem was applied.
Post by Harold_V » Sat May 25, 2019 1:36 am
Hmmm. That's interesting. When I purchased my first BP mill, I also purchased a new vise and swivel base. The vise, which was purchased in 1967, didn't resemble that one at all.
I'm not suggesting that the vise shown is not a BP. What I am suggesting is that it is likely quite old, perhaps one of the first they produced. The one I purchased had straight sides, and was rather square looking, if memory serves. It was replaced, long ago, by a Kurt, which I still have.
I am curious about spro's comment about coolant troughs. I've owned two BP's, neither of which had provisions for coolant, although the T slots ended up in cavities in which there is a female pipe thread tapped for a connector to be added. No troughs along the table edges, though. Does anyone on the board have a table like he described?
ERIE S-1 BERKSHIRES
Post by ERIE S-1 BERKSHIRES » Sat May 25, 2019 8:40 am
As soon as I can figure out how to post a picture I will show one of my three vices and they're dead on except they have Bridgeport cast on it, what he is talking about is a raised lip on the base the coolant will flow towards the bolt openings and then onto the table all bridgeport's vices have that if you enlarge the picture you can plainly see it's on there!!!!!!!!
earlgo
Post by earlgo » Sat May 25, 2019 8:44 am
This is not a Bridgeport table but the Producto-Matic table. Same principle, though.
table with coolant trough
It even has the pipe stub, after all these years.
--earlgo
ERIE S-1 BERKSHIRES
Post by ERIE S-1 BERKSHIRES » Sat May 25, 2019 12:26 pm
As for the rim around the table it's a half moon between the outer T slots and tableside linking tank in the base of the column the coolant tank only seen it on Bridgeport Tracer Mills and special order Bridgeport's with coolant
Post by spro » Sat May 25, 2019 1:05 pm
Harold is right in that 1967 was pretty modern compared to the earlier vises. It became more practical, to have flat machined surfaces instead of rounded castings. Art is not always practical but even the smallest Bridgeports with 9 X 32" tables had at least 3 tee slots. I appreciate earlgo's pic which shows the lip/ trough of a later vise base. We can see it wasn't using or didn't need to use it that way- but it could. I don't mean to get into some disagreement for the answer is very close. Earlgo's pic shows a label peeling away but there is another emblem at the base foot., That data means something too. ERIE S is fantastic in knowing about that too.
The reason I even commented is because certain auctions made an imprint. It was like after this one, I'm done with it. Huge complex and three auctioneers going at the same time. You had to run from one section to another and there was the heavy mills and lathes which I didn't have room for-but I needed to LOOK ! So, run back at the multiple table stands, There must have been 20 Bridgeport milling machine vises. Some had "Bridgeport" cast at the base and some had labels or small, hand rivet, emblems. I couldn't sort this all out but I noticed a few features. To be correct; it didn't impact that any or most had the "outer jaws" feature but the base was of a certain design.
Post by GlennW » Sat May 25, 2019 1:17 pm
Yessir!
With the coolant pump inside "the door".
Post by Harold_V » Sat May 25, 2019 3:36 pm
Thanks, Glenn. That may be a first for me. I was unaware that BP had offered them. The bases of those I've seen don't have a lip, so any coolant that managed to get there would simply run off on the floor, plus the column, inside, is open at the bottom. Obviously different castings throughout the machine.
Any idea of the age of the one shown?
