Poor man's power feed...
Moderators: Harold_V, GlennW
whateg0
Post by whateg0 » Sun Dec 19, 2010 9:37 pm
So, I am working on the design for a power feed using either a wiper motor or a power window motor. I suspect that the wiper motor, designed for continuous duty, is a better idea. But I digress.
In the interim, I have several projects which require the use of the milling machine to true up the edges. My arm got tired after doing the first piece. In comes the cordless drill and some creativity. Nothing fancy, but it sure did work well. And my arm is eternally grateful.
Dave
Bolster
Re: Poor man's power feed...
Post by Bolster » Mon Dec 20, 2010 12:29 am
Clever!
I've been thinking of ways to accomplish this; the first was to drill two opposing holes in the wheel and have some sort of T-shaped, drill-chucked tool enter those holes, but this method requires no mods to the wheels at all...
A Bona Fide Soggy Bottom Boy
mrlucmorin
Post by mrlucmorin » Mon Dec 20, 2010 8:54 am
Good idea.
as an improvement, I'd try to weld a bolt to the end of the axis shaft so I could just put a socket on the drill instead of tightening the chuck on it. This way I could quickly go from one axis to the other.
I'll definitely try to implement this.
Cheers
Luc Morin, T.P.
http://www.stlm.ca
scooterwrench
Post by scooterwrench » Mon Dec 20, 2010 9:37 am
One thing I had thought about was a rotisserie motor used on BBQ's The downfall would be no speed control. I think you're on the right track with the wiper motor, you'll have several set speeds and if used with a variable resistor you can vary those. Most are permant magnet type so reversing is just a matter of switching the leads.There is usually a drop in rpm when you reverse them as they're designed to make the best power in the direction they normally run in.
steamin10
Post by steamin10 » Mon Dec 20, 2010 9:53 am
I have done some wire welding of roundy things on a lathe driven by a drill to get the speed way down.
I had tried to adapt a $2 elcetric can opener to drive the slide on my mill drill, but no reverse, or speed control. I bought a Central Machine for Horror Fright, and have no complaints. It is on my Rockwell, that had a failed drive on it. I had to cut a coupla bushings to make it work, but no big deal.
JackF
Post by JackF » Mon Dec 20, 2010 11:44 am
Dave,
What did you attach the ground to to keep it from winding around the part? Oh wait, did you weld with O/A? :shock: If so, disregard that first sentence. :lol:
Jack.
Mid Day Machining
Post by Mid Day Machining » Mon Dec 20, 2010 2:37 pm
I always thought the best poor mans power feed was on the end of my roght arm.
You can buy good parts, or you can buy cheap parts, but you can't buy good cheap parts.
stevec
Post by stevec » Mon Dec 20, 2010 4:28 pm
Here’s a coupla pics of my homemade mill drill power feed.
The red knobbed handle rotates about 45° right or left of neutral engaging a dog clutch (like lovejoy coupling without the spider) and hits the right or left directional switches of the gearmotor. The neutral position allows using the hand wheel at the other end of the table on my mill drill.
The gray knob on the bottom controls the speed via a KBC electronic speed controller.
The black button on top overrides the gray knob pot. To an overspeed wiring for rapid traverse.
The toggle on the left is “ON-OFF” and the red lens on the right is a pilot light.
The gearmotor came off a label machine at work.
I apologize for not being able to post the pics. If I can figure it out I can edit them in. In the mean time anyone interested could PM me and I'll e-mail you the pics and others, if you're interested
Just proof read and boy! does this suck without the pics :oops:
Lets see if it works.
EdK
Post by EdK » Mon Dec 20, 2010 5:55 pm
stevec wrote:I apologize for not being able to post the pics. If I can figure it out I can edit them in
Steve,
When you go to reply to a posting scroll down below the area where you type in your message and you will see that attached image. You just need to browse to the picture file you want to upload and then click on the "Add the file" button. It's as simple as that. Hope this helps. :wink:
Vectrax 14x40 lathe, Enco RF-45 clone mill, MillerMatic 180 MIG.
whateg0
Post by whateg0 » Mon Dec 20, 2010 6:14 pm
mrlucmorin wrote:Good idea.
Cheers
Actually, the whole thing just slides off of the handle. That way I can use it manually without having to attach anything. I'll try to get another pic tonight with it not on the handle.
Dave
Davo J
Post by Davo J » Mon Dec 20, 2010 7:55 pm
Now thats thinking outside the box, well done. If it does the job that is all that matters.
Dave
whateg0
Post by whateg0 » Tue Dec 21, 2010 3:44 am
Here's a pic of the whole thing. Again, not much to it. Just a couple of pegs to keep the piece from just spinning on the spinner.
Dave
