Millrite vertical mill
oldvan
Re: Millrite vertical mill
Post by oldvan »
Teco makes decent VFDs, one of these the correct size for your motor will
serve you well:
http://www.factorymation.com/s.nl/sc.2/category.32/.f
Rustaholic
Post by Rustaholic »
Any feelings good or bad on ebay item 120668106255
Or http://cgi.ebay.com/HITACHI-X200-SERIES ... 1c18612e0f
OR http://tinyurl.com/65pfjfk
Alan
Rustaholic
My new baby was delivered here today.
I will try for some pictures and have a few new-be questions soon.
ncollar
Post by ncollar »
The machine pictured is a United States Manufacturing Model “MV”. You can get a manual from the Yahoo group.
http://groups.yahoo.com/group/BurkeMill ... l%20Mills/
You must be a member to excess the files. United States Manufacturing sold out many years ago and were bought up by Burke. The statement about a small Bridgeport is the truth. I just do not under stand how you got it down a flight of stairs. I imagine the machine has to be around 1000lbs. I hope to get mine up and running soon.
Nelson Collar
Patio
Post by Patio »
Rustoholic in regards to a VFD
I just went through the discussion here, on the board, about putting a VFD on my mill.
Here is a link to the thread.
http://www.chaski.org/homemachinist/vie ... =4&t=93498
I ended up buying this one, and have no regrets.
http://www.driveswarehouse.com/p-2527-wj200-022sf.aspx
I still have not set up any external controls. They are not needed to run it, but make it a LOT easier to operate.
Hope that helps!
Live for the moment!
Prepare for tomorrow!
Forgive the past!
linx
Post by linx »
I am using a teco 120v to 220v 3 phase for my lathe and it works great. I am using another brand for my Bridgeport and it also works good. I believe the difference is in the ease of programing, also the Teco has a vector drive which gives you a little more torque at low speeds. I purchaced both from Deeler Electric and was satisfied with the service price and shipping. just my 2 cents
Rex
Post by Rex »
I have a couple of nice Mitsubishi VFDs that I use for 3-phase, or which I have none at this time.
However, mine are 220V 1-ph to 230V 3-ph. I understood 120V 1-ph to 230V 3-phase was a big jump up in price.
Can you guys give us model numbers or links to the single-phase units you bought?
neanderman
Post by neanderman »
Rustaholic wrote:My new baby was delivered here today.
I'm not sure where things stand with your move, etc, but I recently moved one of these into the basement of a 100 yr old home (down a flight of stairs), so I might have some tips for you.
Ed
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
linx
Post by linx »
When you have a chance check the current rating on your mill;use this to select the correct size vfd. try to stick with with the teco unit with the vector drive its a nice feature.
wlw-19958
Post by wlw-19958 »
Hi There,
ncollar wrote: I imagine the machine has to be around 1000lbs.
According to my Millrite manual, the "Installed Gross Weight
of Machine" is 1600lbs.
Good Luck!
-Blue Chips-
Webb
Tamper84
Post by Tamper84 »
Cool score. I'm working with low ceiling height and was wondering, what is the total height of a millrite?
Thanks,
Chris
jcbrock
Post by jcbrock »
Chris, my MVN is just under 71". It probably varies an inch or two depending on the motor.
John Brock
