Page 3 of 3
Re: Millrite vertical mill
Posted: Sun Nov 25, 2012 12:50 pm
by wlw-19958
Hi There,
jcbrock wrote:It probably varies an inch or two depending on the motor.
Also, whether there is a 5" or 6" riser under the turret.
Good Luck!
-Blue Chips-
Webb
Posted: Sun Nov 25, 2012 8:06 pm
by jcbrock
71" with no riser in my case, and also that is from the bottom of the base to the top of the motor case, no floor mounts included. An additional consideration is the headroom to pull the drawbar if you need to, although you could rotate the head to the side to do that.
Posted: Mon Nov 26, 2012 10:06 am
by wlw-19958
Hi There,
jcbrock wrote:An additional consideration is the headroom to pull the drawbar if you need to, although you could rotate the head to the side to do that.
You can also lower the quill to gain a little more room for
withdrawing the drawbar. Tilting the headstock will work
of course put re-tramming the head just for that would be
a pain IMHO.
My Millrite is somewhere near 7 feet in over-all height when
you add the riser and have one of the geared-down motors.
Good Luck!
-Blue Chips-
Webb
Posted: Mon Nov 26, 2012 10:13 am
by Tamper84
That is a nice looking mill!! How hard was it to add the dro to it?
Thanks,
Chris
