The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Tue May 21, 2013 5:19 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4  Next
Author Message
PostPosted: Tue Mar 13, 2012 4:07 pm
Offline
Glenn Wegman wrote:
Try Zep Citrus Cleaner in the trigger spray bottle.
OK Martha Stewart! :wink:
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 4:10 pm
Offline
Huh?
I've NEVER been to prison... :)
_________________
Top
 Profile
PostPosted: Tue Mar 13, 2012 5:23 pm
Offline
I can tell you what I would do, and what I did with my SB9 last summer:
I bought a gallon of WD40 and a trigger sprayer.
Loaded up the lathe and went down to the coin-op car wash. I pressure-washed that thing everywhere I could reach.
Quick trip home. Air nozzle to remove most of the water.
Then I applied WD40 generously, aided by a stiff brush or three, some gray scotchbrite, and the occasional rag.
Cleaned up great, no re-paint required.
I did this with my Centex/Rockwell mill last month, major pieces only as it wasn't as dirty.
base, column, knee (you would not believe all the muddobber nests!), table
Top
 Profile
PostPosted: Tue Mar 13, 2012 6:43 pm
Offline
Good news - the varnish-like gunk seems to be shellac, and completely dissolves in cheap rubbing alcohol (WD40 or mineral spirits won't touch it). I've got a lot of it to clean off, but it looks like being a relatively quick process once underway, and and not too stinky :mrgreen:
cheers
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 6:52 pm
Offline
Let the WD-40 do for you what you want, but get it "off" before you go on.
The "water displacing" properties attract H2O and then some of the solvents/evaporators evaporate and leave the water on the clean "anxious to rust" surfaces.
Top
 Profile
PostPosted: Tue Mar 13, 2012 8:00 pm
Offline
huh? Alcohol is the solvent. As I said, WD40 won't touch the gunk (shellac), which is spirit-based. Rubbing alcohol has a certain amount of water in it, so the bare metal needs oil. WD40 works just fine as a short-term rust deterrent.
Don't worry, I've got a few brain cells left despite 40 years of breathing solvent fumes and bathing in parts washing tanks :mrgreen:
cheers
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 9:59 pm
Offline
I agree, and don't understand how it has earned a reputation for not serving in that capacity. I've used it enough to know that when it evaporates, it leaves behind a film of what I would best describe as paraffin. I had to leave my Wells A7 saw in our pump shed while building. It started to rust, but was controlled to my satisfaction by spraying with WD-40. Nice part is, it's easy to clean up. A new application and a wipe with a cloth and it's pretty much gone.
Nice discovery on the alcohol solvent! From your description I would have never suspected shellac. Things shoud clean up like new!
_________________
Top
 Profile
PostPosted: Tue Mar 13, 2012 10:06 pm
Offline
I left off the last step, which was the liberal application of specified lubricants to the overflow point, wiped down with a clean shop rag.
No WD40 left in place.
Top
 Profile
PostPosted: Tue Mar 13, 2012 10:45 pm
Offline
Harold - The one-man shop where the mill and lathe came from made reproduction Renaissance wind instruments during the 1970s. From looking around what remained of the shop, I gathered the SB was used to bore the long hardwood cylinders with shop-made gun drills and contour the outside profiles of the cylinders using a compound-mounted hydraulic tracer.
So I could understand why there was wood dust all over the machinery, seemingly mixed with old oil and solidified into what looked like a 'varnish'.
But until a moment ago I couldn't think what process would call for using shellac in and about the lathe... Then the penny dropped - holy cow, the guy was doing French-polishing on the wooden parts while spinning them in the lathe :roll: No wonder the un-Godly mess :evil:
But then why is it all over the milling machine as well? :?
Shaggy
Top
 Profile
PostPosted: Tue Mar 13, 2012 10:51 pm
Offline
Sloppy work habits? :lol:
Any internal polishing, where they may have spun a tool?
_________________
Top
 Profile
PostPosted: Wed Mar 14, 2012 10:57 am
Offline
Anyway, just to end this topic...
Thanks to all who offered advice of any sort, now that the Rockwell has been successfully moved and I can rest my back. :D
Shaggy
Top
 Profile
PostPosted: Wed Mar 14, 2012 6:03 pm
Offline
The topic isn't quite closed as to spontaneous combustion. Shellac was one suspicion and another is linseed oil. It is generally accepted that Any metal wool or shop towels in contact with both alcohol and these type finshers are prone to combustion. A fire-proof recepticle, preferably outdoors, is the way to go. Look it up.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
