tornitore45 wrote:
Thanks, why did I not think of that.
To paraprase your instructions ...
Work the 12:00 and 3:00 sides trusting the dials with allowance for the actual mill dia. Stopping at 1:30 and 4:30. I am milling conventional and in the positive direction.
Assuming you have used the left side and top side as your reference (picked up with an edge finder), you would machine the 3:00 and 6:00 sides by direct dial reading, compensating for cutter radius. When I speak of the top side, I am making reference to the 12:00 side of the part. From your description, you would have referenced the 6:00 side, but that causes you to read the dial in reverse. Not a problem, but it can be confusing if you are not very comfortable with working dials backwards.
Quote:
Now I have two sides to reference a measure.
Correct.
Quote:
Reverse the handle until the backlash is remove. Move less than full travel to leave a smaller pocket than nominal, using the dial as differential move neglecting the absolute reading. Still conventional milling.
Same for the forth side.
Direction of travel in making the cut can be climb or conventional, considering you are machining a slot initially. Once you have opened the window, however, climb milling can be troublesome if you have a loose machine, or it is light duty. I did my finish passes by climb milling, but I would remove only a few thou, so it wasn't troublesome. Let that be the guide for your selection in the direction you prefer to feed.
The bottom line is, once you've established the relationship of the dial to the cut, you can trust the dials in either direction, because what you've done is account for the amount of backlash at that particular place on the screw. If your screw can be trusted to a thou, it will repeat within a thou.
Quote:
Now climb mill all around trusting the dial in the positive direction, measuring and adjusting in the negative direction.
That would be correct for both semi-finishing and finishing, assuming your machine is robust and does not yield problems with climb milling. Climb milling almost always yields a better surface.
If you have recorded the proper stopping points for each side of the window, your final pass can be one smooth movement for all four sides. There won't be any witness marks in the cut. Keep the markings where they are visible wihtout taking your eyes off the cut. That's why I often make the + on the vise, or the table, near the cut.
