As they say a photo (even a not very good one) speaks a thousand words!
Here, principally for you, Harold, is the wing nut job. Extreme right is the wing nut itself that needs the concave cut-out at the left hand end. It screws onto the end of the rod. Positioned on the rod is the cylindrical cross piece that when everything is fitted up will seat between the jaws of the brake lever and which the concave of the wing nut will fit around. At the extreme left is the fork, screwed onto the rod. This holds the whole assembly to the brake pedal with a clevis pin.
File comment: Photo of wing nut
Rex suggested holding the wing nut vertically in a milling vice using the wings. This was a very good and logical suggestion. The wisdom here was (totally unsound) that the wings have to be at right angles to the axis of the concave.
It obviously doesn’t matter a damn, but I accepted the ‘accepted wisdom’ which negated Rex’s sound advice. Thus I devalued the set-up considerably by trying to hold the wings horizontally.
Someone else (Glen?) suggested inserting a rod in the thread of the wing nut and using that as a ‘holder’. That was another very helpful idea. I actually used the rod that is part of the assembly. Packed out the fork end to add rigidity and held that by its cheeks in a second vice.
I intended to use a ball-nosed end mill to cut the concave. Rex said an ordinary end mill was all that was needed. Absolutely right (again). That’s what I used – two in fact, one to make the initial shape and a larger diameter to widen the radius. I guess the perfect cutter would have been a slot drill. Not sure (any thoughts?)
Happy ending? Not quite. Towards the end the wing-nut moved in the vice. I abandoned milling and finished the job with files.
I am, as of today, not a good miller. I’ve learnt a huge amount from this brilliant site and its equally brilliant people. One, when milling, make it all run true by using test gauge indicators on the vice etc etc.
But, am I under-estimating the need to HOLD firmly. I’m using drill press vices and a-not-very-high quality tilting vice that came, as a freebie, with my machine.
I’m saving up for a Vertex milling vice. That’s a Taiwanese make that I think is pretty good. I have their chuck for milling collets and it seems A1. I can’t afford a Kurt and I don’t think they are available in France. Record are astronomically expensive and I don’t think they make machine vices (only bench jobs).
Will a good milling vice help me?
Martyn
