Oil reservoir on Rotary table (Ro-tab)?
When I cleaned up 6" rotary-table, I saw a sticker that said, oil plug. Another sticker says fill with oil be for using. Then what looks like a clear site gauge. I never expected that. Does it really need oil for turning the plate around?
Re: Oil reservoir on Rotary table (Ro-tab)?
Prolly wouldn't hurt!
They usually use an oil bath for the worm gear inside rotary tables, at least the larger ones I have seen. So yeah, they will have a fill plug and either a sight or level indicator on the fill plug.
Thanks Guys I'll add some fine grade oil.
- SteveHGraham
Don't be amazed if it slowly leaks out.
Had a design change, wont be needing the rotab, no oil add.
Thanks
Vern
Thanks
Vern
