Pinnacle Milling Machine
- juiceclone
Re: Pinnacle Milling Machine
socket on the top nut with an air impact wrench..amazing what inertia can do
Eventually managed to loosen and remove the holder today.Can anyone confirm from the photos if it is indeed an R8 collet holder or some other type.
Thanks. Brendan
Thanks. Brendan
You can lead a horse to water but a pencil must be lead...
Your pictures show everything EXCEPT what is needed ! That indeed is some form of collet system . But in your first picture we can not see the shank of the body to tell what it is,post a picture of the body showing the shank ie at 90* to it. From the little i can see looks like a R-8 but can't tell for sure.
www.chaski.com
This is another picture
Just by look, that appears to be an R8, but I've never seen one where the keyway extends onto the taper.
Yes it does look to be a R-8 ,but I'm with Russ on the keyway being that long. Being the OP is on thefar side of the pond who knows where that collet was made. If I was the OP I would just order up a R-8 to try,or maybe a local shop etc. might have one to compair it with. But the actual collet system in that holder is strange indeed to me.
www.chaski.com
You may find this page useful as it has a drawing of the R8 dimensions.
http://www.oldengine.org/members/diesel ... rkson3.htm
--earlgo
--earlgo
Glad you succeeded to remove the holder, it does look like R-8.bren4finn wrote:Eventually managed to loosen and remove the holder today.Can anyone confirm from the photos if it is indeed an R8 collet holder or some other type.
Thanks. Brendan
It would be nice if you could tell us HOW you succeeded in the removal, was it by following any specific suggestions that were provided?
I tightened the vice to the table and raised the knee up until the holder was positioned between the vice jaws then placed a strip of neoprene rubber around the collet holder and carefully tightened the vice (moving the table accordingly) until the spindle stopped turning while I loosened the drawbar. It actually didnt reguire much pressure as the rubber strip proved a good friction material. Unorthodox im sure but proved to be effective. .
I was looking for information on a Pinnacle PK-1 1/4 Knee mill built in 1981 and found this old post. Here's a link to the Pinnacle site that may be of interest. The mills are offered with several spindle configurations. My mill is not listed.
David WC wrote:I was looking for information on a Pinnacle PK-1 1/4 Knee mill built in 1981 and found this old post. Here's a link to the Pinnacle site that may be of interest. The mills are offered with several spindle configurations. My mill is not listed.
Good Morning David WCDavid WC wrote:I was looking for information on a Pinnacle PK-1 1/4 Knee mill built in 1981 and found this old post. Here's a link to the Pinnacle site that may be of interest.
Okay..My Eye's are old Where is the link
Ken.
One must remember.
Ken.
Ken.
Ken572, The mind is a terrible thing to lose. I really thought I had included the link in my post. http://www.pinnacle-mc.com/en/pinnacle.pdf The Manual mills are at the bottom of page 14.
