Tender Build
Re: Tender Build
Post by NP317 » Fri May 26, 2017 10:51 pm
I've decided on the metal water tank sealant: U-POL Raptor truck bed liner.
https://smile.amazon.com/U-POL-5010-Rap ... ptor+liner
This 2-part bed liner has been used by a fellow Live Steamer with good results. It is supposed to remain flexible after curing. I've not seen his results in person; Just have his recommendation.
The tender tank interior has been primed with a flat automotive paint, which should bond well with the liner material.
The bottom is powder-coated and it's beautiful smooth surface will be scuffed, cleaned, and painted with this compound designed to increase adhesion of the Raptor liner:
https://smile.amazon.com/U-Pol-Products ... er+-+450ml
If any of you have experience - good or bad - with this material, I would appreciate your comments, especially before I use it!
I hope to get to this task in several weeks. I'm still finishing some electrical trouble-shooting and improvements to my 1973 Datsun 240Z, purchased new by my mother! It's in prime original condition, a daily driver, and worth keeping me away (for a little bit...) from my beloved steam projects!
Re: Tender Build
Post by NP317 » Wed Aug 23, 2017 9:46 am
Have made some progress on handrails and riveting the tank to the base plate.
I am now preparing/sealing the tank bottom, prior to coating the interior with the Raptor bed liner.
Most of my time has been doing good-weather outside projects, preparing for winter. Also shopping for a new pickup truck. Every 18 years or so... This will probably be my last one ever, and 4-wheel drive for the snows here. Getting snowed in here simply provides shop time to make more progress on the locomotive and tender!
The handrails are 3/16" steel rod, heat-bent over mandrels designed for the job. Then brass "pads" are silver brazed onto the ends, and drilled for mounting bolts.
Lots of fiddly work, but the results are robust and look OK.
Glenn Brooks
Re: Tender Build
Post by Glenn Brooks » Wed Aug 23, 2017 9:21 pm
Hi Russ,
Great job on your tender riveting. What size rivets are you using and what material are they? I'd like to try something similar...
Re: Tender Build
Post by NP317 » Thu Aug 24, 2017 11:12 am
Glenn:
Those rivets are (I believe) 3/32" diameter, steel. Not difficult to set. Four WHACKS! with the hammer against the set tool.
They are the standard ones supplied with the Locoparts tender kits.
Worked well.
Off the subject, yesterday I bought a new Chevy Colorado crew cab long bed truck! Feels really big compared to my 2K Ford Ranger extra cab.
Technology improvements: Ranger: 3L V6, 160 HP. Colorado 3.6L V6, 300+ HP. Same or better gas mileage. I like that.
Now I need to change the height of my two locomotive stands so I can haul The Beasts in this new truck.
Cause / effect. So goes life. But I expect this to be my last truck purchase. They can haul my ashes away in it decades from now.
Life is good and we get to build large-scale train stuff.
Glenn Brooks
Re: Tender Build
Post by Glenn Brooks » Thu Aug 24, 2017 12:31 pm
Russ, 4 WHACKS x 750 rivets = a lot of whacking of rivets. Looks great though- well worth the time.
Iam impressed with your new truck. Very surprised about the gas mileage. I'd like to step up, literally, into a new full size pickup and likewise sell my old ford Ranger. Not enuf payload for larger loco's...
Stop by for breakfast some Wednesday!
BobCoalBurner
Re: Tender Build
Post by BobCoalBurner » Sun Aug 27, 2017 1:25 pm
I've been excited about following this post. I have the same tender kit and I will be needing to do the same extension of the top rails and possibly shortening the tender but I kind of like the idea of having somewhere nice to sit. I was hoping you had some pics on how you bent and installed the 1/2 round edging. Do you have pics of locomotive that will be pulling that tender around?
makinsmoke
Re: Tender Build
Post by makinsmoke » Sun Aug 27, 2017 2:40 pm
Jack Bodenmann has dealt quite finely with the subject of tender obstruction and to the bending and installation of the half round. In fact, he shows how to make your own!
Use the search function and look for his tender articles, possibly for the Disney American.
I've seen the Santa Fe practice on the subject, and they simply riveted them onto the top edge of the tender side/flare, and gave no thought to filing away the heads to make them flush.
By the way, has anyone heard from Messr. Bodenmann lately? I miss his posts, though the lack of seems to have freed up quite a bit of my time...
:lol:
Re: Tender Build
Post by NP317 » Mon Aug 28, 2017 10:02 am
BobCoalBurner:
Looks like you are also building the 90-ton Mikado. RR Warehouse.
Attached is a blurry shot of my loco. It runs on air nicely.
I've had a bit of a setback. Wife K has two seizures last Thursday. To more nights spent in Portland hospitals. Home again, but dealing with the results.
Re: Tender Build
Post by NP317 » Mon Aug 28, 2017 6:14 pm
Glenn: I'd be delighted to join the KLS Brunch Bunch again on those Wednesdays. But it's now a 4 hour drive to get there from my home...
BobCoalBurner: I forgot to compliment you on your 2-8-2 locomotive. Looking good!
Also, about bending the brass half-rounds to line the top rails of the tenders:
The first LocoParts tender kit I assembled did require bending the half rounds. Instructions included a description for making a bending jig consisting of two angles rollers mounted to a flat plate. Manually bending of the brass around those rollers kept the half-round flat against the plate. Worked fine.
The second LocoParts tender kit included pre-bent half-round sections. 'Felt like cheating!
So contact Jeff @ LocoParts to see if he will sell you the pre-bent pieces!
Re: Tender Build
Post by NP317 » Tue Aug 29, 2017 9:11 am
And BobCoalBurner,
Please tell us about the 2-8-2 you show in your two pics.
I'm trying to gather info on any and all such small Mikes.
BobCoalBurner
Re: Tender Build
Post by BobCoalBurner » Fri Sep 01, 2017 12:15 am
Hi Russ,
My thoughts and well wishes to you and your wife during this difficult time.
Your locomotive looks great. I hope to see more pictures of it as it progresses. As far as my loco goes, it might be RR Supply castings but I don't know much about it. I haven't really asked around and I am still relatively too new to yet recognize casting suppliers. I do know it came out of a place called Hartford Shop from a guy named Tom...ArtzSomething. It was constructed as an Alco tank loco so I am not sure if it qualifies as a 90 ton? Don't know if Alco made a 90 ton either? The tank and bits were too far past refurbishment for me, time wise. Besides I wanted a 2-8-2 with a standard tender anyway so it has just been a boiler and rods off restoration. It did run decent before I tore into it. I recognize your locomotive 317, not sure at what track, but if you can see MT Hood I think we both might be within rock chucking distance from each other.
Re: Tender Build
Post by NP317 » Fri Sep 01, 2017 9:38 am
BobCoalBurner wrote:Hi Russ,
Bob:
Thanks for the well wishes. I'm happy to note that Wife K is improving quickly...again. 'Hope this is the Last Adventure. We don't need this kind of excitement in our lives.
And also thanks for the info on your 2-8-2. Tom Artsburger is known for his craftsmanship. You might have a gem there.
The front deck casting is different than the RR Warehouse castings, but the rest sure looks familiar. 'Hope to see it someday soon.
I live 16 miles north of Mt. Hood, just off Hwy 35, directly south from Hood River.
Toss a rock my direction, and lets get together if we're really that close!
~Russ Noe
