Another CliShay Build
bill4227
Re: Another CliShay Build
Post by bill4227 » Tue Jan 07, 2020 8:54 am
Scotty,
Have you built the Big Bertha replacement engine? Any pix?
Bill
ChipsAhoy
Post by ChipsAhoy » Tue Jan 07, 2020 9:09 am
Bill:
No. There are 5 of us building one CliShay. We have broken the build down to divy up the work. My first section to build is the frame with the jackshaft. When that is complete, my next task is to collect the parts to build the "flame in tube" boiler.
The two fellows who are partnering up on the engine, are just finishing the trucks and beginning to collect materials to build the Big Bertha. So, the engine build technically has begun.... but no significant progress as of yet.
We at Maricopa Live Steamers, are beginning the work week leading up to the January Open Card Order Meet, for the 7.1/2" and the 4 3/4" guages, so work on the CliShay will slow down for probably a month.
Scotty
bill4227
Post by bill4227 » Tue Jan 07, 2020 1:24 pm
Thanks Scotty. I would be interested in how the Bertha engineering goes as to reverse linkage.
By the way do you know Larry Kirchner at Maricopa?
Bill
ChipsAhoy
Post by ChipsAhoy » Tue Jan 07, 2020 2:08 pm
Bill,
I do know Larry, his container is right next to mine (ours, 3 owners). We are kinda working on improving the same area of track by installing plastic ties that he purchased.
Scotty
bill4227
Post by bill4227 » Tue Jan 07, 2020 2:43 pm
Scotty,
I have known Larry for a long time. Say hi next time you see him from Bill at CALS in Baltimore
jeanluc83
Post by jeanluc83 » Tue Jan 07, 2020 5:32 pm
It's good to hear that the Tom Bee couplers will work. How much side play is appropriate? I calculate it as about 8° in each direction with the shank and the coupler pocket as is.
I'm still planning to go per plan on the engine and transmission.
jeanluc83
Post by jeanluc83 » Mon Feb 03, 2020 11:55 am
After about a two week shop hiatus I managed to get the shift rod assembly done this past weekend. The assembly is used to connect the reach rod from the reverse lever stand to the transmission. It was a fairly simple part to make but with enough different operations to make it interesting.
I decided to silver solder the parts together in lieu of the Loctite called for in the plans. I haven’t done that much silver soldering so it gave me a chance to practice some more. It also means I will not have to worry about it coming apart in the future.
