Great work Pamela, what air compressor are you using?
Regards
Garry
Hudson Honey wrote:I have a miller 130 mig and a miller maxstar 150 S or H tig/arc (whichever is the frequency arc...meaning one does not touch the electorde to the metal. a frequency arc draws the torch).
took a detour today and fabricated the "T" slot plates that get mounbted to the rail board for transport of this beast. still need to drill and counter sink mountoing holes and clean them up and paint. the large T nuts are partially fabricated will show photos when they get a bit farther.
Bleh......I'm in a funk. the lock down clamps are taking forever. waiting for stuff to come........
I need to take a side line this weekend and make a couple reversing quadrants.
I suppose the third piece of wrapper can get mounted and then make the patterns for cutting the wrapper.....and the smoke box pipe for the access cover to the throttle assembly.
mulling around ideas for making the worthington pump and air compressor mounts. hard to see exactly how it goes from the photos....so I will be filling in the blanks freelance.
the T nuts are machined...a lil deburring yet to be done....and weld in the studs.
the straight clamps are done.......the off set clamps need some trimming and then weld them together.
the T rails need to be mounted down....
I think you get the idea of how they work. the toe clamp hooks the driver thru the spoke slot....level the clamp withe the rear jack screw......lock down the large nut. loco will not move at all. the designer, Paul Keiser, has been using them for 4-5 years...with several cross country trips...and the big 9100 ( the sister to my 3464) did not budge.
tomorrow it's to home depot for another sheet of plywood to make the tender rail board. they will be joined with 6 4 foot 2 x 4s under the rail boards.
