Victorian R-CLASS 4-6-4
Re: Victorian R-CLASS 4-6-4
G'day Dick the square return crank holes took a bit of thought as there has been a lot of different ways of doing them described on different forums from dummy squares and the like I chose to try & do them properly as you can see in the photo of the completed cranks there is a third one which was a reject .
First I marked out the square using the digital read out on the mill then drilled the centre out to a couple of drill sizes smaller then carefully filed out the square to just under size I then milled up a square on the end of a piece of silver steel then I concaved the end slightly with a 3/4" ball mill to form a sort of broach I then pressed it through the already filed holes keeping it as square as possible I did not harden the silver steel square section as it was only a one off job I did not think to take any photos the first time I tried it did not turn out correctly one of the reasons I had to remake one, the second time round it is all ways easer still a long way to go
One other thing is does any body no what's happened to Hudson Honey I was following Her Build with great interest
but haven't see any posts for quite some time?
Gary
Gary
What scale has this been built to?. Thanks in advanced.
Very nice work! Could we see some details on that neat building stand?
The builder said it is 5" gauge. The prototype was Australian broad gauge 5'-3" so it is 1" scale or close to.
