Victorian R-CLASS 4-6-4
Re: Victorian R-CLASS 4-6-4
Gary, The truck looks great. My GS-4 trailing truck is fabricated from steel by tig weld and silver solder, so I can definitely appreciate your efforts. It looks like you added bits of silver solder to the sides of the retainers where you milled the grooves to create a fillet, nice touch. How did you make out on finding your stainless fasteners?
Vic
Vic
For Duty and Humanity
G'Day Vic & Dick thanks for your comments yes the bogies are quite time consuming one part at a time & hopefully
one day it will be in steam long way to go yes i have bought the s/s caps from ebay the bigest expence was the freight
they were for my freelance loco which i built some years ago the caps are for the dome plate the orignal retaing screws were only steel i thought it better to replace them before they are to rusted, off on holidays tomorrow will
be back in the W/S in 3 weeks
Gary
R-Class hudson 4-6-4
Gary
G'Day all not a lot of progress since going on holidays, while on holidays we decided to
upgrade to new larger RV with built in shower & toilet (just to keep powers to be happy)
when i got it home i had to raise the garrage roof to 3.3m to accomidate it which has kept me out of the workshop & away from the loco build all finished now & some progerss on the r-class build
A little progress on the boiler today , front throate plate soldered with brace not the neatest soldereng but acheived good penatration i needed another pair of hands
Tender equlising beams made in two halves & then riverted & silver soldered together
G'Day all just finished the tender bogie axel keeps, all was going well until i used the slitting saw to part them off in doing so i forgot to allow for the thickness of the blade
which made them to thin not enough metal to mill the stiffening web on the bottom
rather than remake them i silver soldered on a web, moral of the story is to measure twice & cut once
Today i soldered the bogie (truck ) frames together,made a jig to keep every thing square, still some brake mounting brackets to solder on , next job axel boxes & wheels then brakes
G'Day All some progress on the bogies lots of fiddley bits made, time cousuming axle box covers fitted brake hanger mounts fitted at present working on dummy springing which is fitted inside frames with coupling links tempory fitted bogies to frame jus to see how it looks also soldered boiler barrel to outer fire box wrapper will post pix later
- JBodenmann
Hello My Friends
Heavens to Betsy what amazing workmanship. The tender truck bogies are most excellent along with the rest of your work.
Looking forward to seeing more.
Jack
Jack
- Steamchris
Hey ,
i just can follow jack, amazing!!!
Your way to create these trucks remember me on my dad`s way to create his trucks.
Power further so, thats the way it should be......
All the best and a lot stamina ....Chris
The light at the end of the tunnel could be a train
Health and Safety Notice
due to the current economic circumstances , the light at the end of the tunnel
has been switched off !
Hi Gary,
Congratulate you on your most excellent work. Truly unique sheet metal work in Live Steam.
Looking forward to your future work with great interest.
Best regards,
hudson
NB. I found today a nice video on a doubleheader of R class locomotives:
http://www.youtube.com/watch?v=NPg1DGIdi-0
Best regards,
hudson
