Page 7 of 11
Re: Victorian R-CLASS 4-6-4
Posted: Wed Jul 09, 2014 3:37 am
by VK2DJ
A couple more pix of progress
Posted: Wed Jul 09, 2014 3:04 pm
by hudson
Hi Gary,
Really well done. Congratulations.
I work on the promised translation. You will get it soon.
Best regards,
Hudson
Posted: Wed Jul 09, 2014 3:29 pm
by kenrinc
Your work is first class all the way. I love the fabricated trailing truck. Awesome!
Harold, I think this belongs in the build logs....
Ken-
Posted: Wed Jul 09, 2014 6:14 pm
by VK2DJ
G'day Ken when I started this thread I did not know about the build log maybe somebody could tell me how to transfer it over
Regards Gary
Posted: Thu Jul 10, 2014 3:30 am
by Harold_V
kenrinc wrote:Your work is first class all the way. I love the fabricated trailing truck. Awesome!
Ken-
Done!
Posted: Fri Jul 25, 2014 6:27 am
by VK2DJ
Hi All a little more progress on the pony truck, just need to find some suitable material to make the leaf springs to complete the suspension then the wheels & axles to complete the assemby
Posted: Sun Jul 27, 2014 5:42 am
by Vr160
Just pure awesome work, Looking forward to the wheels and axels to complete the pony. Vey nice
Posted: Mon Jul 28, 2014 3:09 am
by VK2DJ
G'day All some progress on the boiler for the Hudson while waiting for materials for the pony truck made up a set of clamping rings
to hold the barrel while drilling & boring, temporary assembled & trial fitted the stays to check for clearances all ok still a little shaping on the inner fire box back plate then ready for soldering
Gary
Posted: Fri Aug 01, 2014 12:45 am
by Vr160
Do these boilers run better with a brick arc and syphon tubes, or it does'nt really make a difference? What is the operating pressure?
Posted: Fri Aug 01, 2014 9:15 am
by R707
Vr160 wrote:Do these boilers run better with a brick arc and syphon tubes, or it does'nt really make a difference? What is the operating pressure?
I think the design pressure for this R class boiler design is 620kPa (90psi) - or perhaps Gary has altered his design to suit the max allowable 720 kPa (100psi).
For loco's in 5'gauge, a 'Brick Arch' (really just a 5 - 6mm steel plate) does generally improve combustion in the firebox (extends flame length) - but syphon tubes no. The reason generally given for this is it makes the water too turbulent over the crown of the firebox; thus risking the ejection of water when the safety valves lift or carry over into the pipes of the steam manifold.
A nice long combustion chamber will ensure firebox gasses can burn completely, and with a large grate area sitting directly behind it - Gary's boiler should steam like a witch!
[ I should prob add I'm a one-eyed R class fan and have my own 5' model that currently only exists as a set of driving wheels ...
Posted: Fri Aug 01, 2014 8:56 pm
by Vr160
Thanks for the info R707. I too like the R class, well better add the J too I can't split them. The syphon tubes explanation make good sense. I was curious about the arch, I know on one of the NAs at Puffing billy they had a problem with a poor steaming boiler and they made a small adjustment to the brick arch and now you can't shut her up. Steams very well. Whats the reason behind the max 100psi in Australia but the US run I think at 120psi? Do you have any pics of your R?
Posted: Sat Aug 02, 2014 5:27 am
by R707
The 100psi max working boiler pressure is entirely dictated by the AMBSC (Aust. Miniature Boiler Safety Code) - which is a set of design rules for designing a copper boiler and specificies an inspection and testing procedures by approved boiler inspectors. Its all about insurance - so a boiler built and certified to the code is covered. You can read more here;
http://www.aals.asn.au/AMBSC/AMBSC.htm
As for progress on the R - its barely emerged from the drawing board...!
https://plus.google.com/u/0/photos/1030 ... 0114574849
I do however run a forum called '3D Printing for Model Engineers' which (apologies for the FB link) which assists modellers with utilising 3D printing technology & invest cast parts for their build projects...
https://www.facebook.com/groups/1415059758757262/
