Another 2900 project...
LSGOD
Re: Another 2900 project...
Post by LSGOD » Thu May 24, 2018 12:17 am
Kimball McGinley You make your models your way. We will make ours our way.
SF2900
Post by SF2900 » Mon Sep 17, 2018 7:18 pm
Things are progressing along. It's actually starting to look like a locomotive.
Steamchris
Post by Steamchris » Wed Sep 19, 2018 2:48 am
Hi Sf 2900,
what an impressive look, i like your work on the timken parts very much, keep up the good work!
How big is the Volume of the Boiler?
All the best
Chris
Health and Safety Notice
has been switched off !
SF2900
Post by SF2900 » Mon Oct 01, 2018 11:14 am
Boiler is 12 3/4" OD with 3/8" thick walls. It is 42" from the front flue sheet to the rear flue sheet which would make the gross volume approx. 4,750 cubic inches. FYI, the smoke box is 22" in length and the firebox (measured at the top) is 21" in length.
-Ward
Asteamhead
Post by Asteamhead » Mon Oct 01, 2018 3:46 pm
Hello SF 2900,
That's a very big boiler, indeed! And we thought our boilers for the Y, my A and the J under construction were big ones :lol: but that of your fat 2900 is about 50 % bigger!
Like that engine, the prototype of which will be returned to service next? year, too. I got a lifelong membership of the club 2926 this year. Saw the engine and her sister 5011 at Sacramento more than 20 years ago.
Go ahead and please continue reporting about your fine work!
Asteamhead
SF2900
Post by SF2900 » Thu May 09, 2019 7:35 pm
Smoke box front. Photo is a bit dark.
SF2900
Post by SF2900 » Thu May 09, 2019 7:37 pm
Smoke stack and base.
Berkman
Post by Berkman » Thu May 09, 2019 7:39 pm
Very nice. was the rear cradle from a casting or did you fab it ?
SF2900
Post by SF2900 » Thu May 09, 2019 7:43 pm
Fab. Draw, cut, weld. Rinse and repeat.
Berkman
Post by Berkman » Thu May 09, 2019 7:53 pm
It looks great. The rear end of the cradle looks like a casting! so nice work!
Rob Gardner
Post by Rob Gardner » Fri May 10, 2019 8:00 pm
Ward,
Will the smokebox be jacketed and or lagged? On the C&O J3a's, the smokebox had jacketing but I can't tell on the erection drawings if they had lagging as well, though I doubt they did.
Thanks,
Rob
makinsmoke
Post by makinsmoke » Fri May 10, 2019 9:24 pm
Most later locomotives has lagged and jacketed smokeboxes.
