Another 2900 project...
JBodenmann
Re: Another 2900 project...
Post by JBodenmann » Mon Mar 09, 2015 11:04 pm
Hello My Friends
Very cool fabrication of the trailing truck. Cut, form, weld on the dotted line. A most delightful puzzle you have going there.
Jack
SF2900
Post by SF2900 » Thu Mar 19, 2015 12:00 pm
Finally got all of the round and oval inserts completed and welded in place as well as the eyebrows. Getting started on finishing and installing the top pieces. Yes, it definitely seems like a puzzle at times - one that I am never totally sure that I have the right pieces for. :)
jschoenly
Post by jschoenly » Thu Mar 19, 2015 1:20 pm
It's a gorgeous puzzle though!
Jared Schoenly
Cabin Fever Expo
Model Engineering of all sorts.....
SF2900
Post by SF2900 » Fri May 08, 2015 12:46 pm
Continuing on with the puzzle theme, we have made a bunch more pieces and are fitting them to the frame.
Added the brake lever brackets
Lots of cutting, fitting, sanding, grinding, and burning of fingers getting all the pieces to fit.
Final fitting before pedestals were welded onto frame sides.
GS14403
Post by GS14403 » Fri May 08, 2015 3:43 pm
SF2900 wrote:Continuing on with the puzzle theme, we have made a bunch more pieces and are fitting them to the frame.
The puzzle is a lot easier to solve when the puzzle master is there to help you along. I know, that is how my trailing truck went together as well. I was a bit luckier than you though. My trailing truck has no brakes. Much simpler.
Looking good.
Donald
PSeyfrit
Post by PSeyfrit » Fri May 08, 2015 7:03 pm
I'll take the burning of fingers is optional.
Paul
Maryland
Club website http://calslivesteam.org
SF2900
Post by SF2900 » Mon Jul 20, 2015 11:17 am
Work on the trailing truck continues. More of the same - making little parts, fitting, finger burning, welding, grinding, and sanding. Repeat. Ed directs and does all the welding while I do most of the sanding and finger burning. But, I am more than happy with the results.
Asteamhead
Post by Asteamhead » Mon Jul 20, 2015 3:23 pm
Nice workmanship, indeed! Please continue to post your progress to us modelers!
Lasered parts, bent, welded together and milled then to the precise dimensions. Your's is the same methode I prefer to make those parts for my A 1239. Making patterns annd to cast just a few parts for one single engine mostly won't pay off.
Please look the photos of brake hangers just in production.
Asteamhead
Still a lot of milling work yet to finish the outline dimensions!
SF2900
Post by SF2900 » Mon Feb 08, 2016 6:54 pm
Really slow but sure..... It is time to make 2 halves into a whole.
-Ward
Fitting up the final top piece on the TT frame.
Fitting the 2 sides together!
SF2900
Post by SF2900 » Mon Aug 29, 2016 11:41 am
With the addition of the brake lever brackets and some gingerbread, the trailing truck frame is nearing completion. The leaf springs and most of the suspension parts are complete as well. The journal boxes and axle assemblies are done. Just need to finish the brake rigging and it will be time to start putting things together. Some initial test fitting has already shown that my fingers are way too fat to get inside the frame to put things together and it will take some creativity to get everything assembled.
- Ward
Carved the journal boxes out of aluminum. The CNC mill comes in real handy on stuff like this.
Pontiacguy1
Post by Pontiacguy1 » Tue Aug 30, 2016 8:38 am
Where did you get those Axle Box covers with Timken on them, and what size are they?
SF2900
Post by SF2900 » Tue Aug 30, 2016 3:00 pm
Ed made a mold and had the jbox covers cast. I am not sure the size but can measure it at the next work session.
