Building the 2.5" Scale Shay
Soot n' Cinders
Post by Soot n' Cinders » Mon Feb 27, 2017 10:25 am
They probably won't. And I'm sure the line between the turret throttle and backhead throttle is blurred as well so there may have been a 20 tonner with a backhead throttle. Lima wasn't always too consistent with the shays and who knows what all was done to them once they got into the hands of the backwoods logging shops.
And that mug is out of scale haha. It and the cylinders shouldn't be on the tank deck anways.
-Tristan
Projects
jcbrock
Post by jcbrock » Mon Feb 27, 2017 4:30 pm
I did a backhead throttle too, so at least if we are wrong we are consistent...except for Brian!
John Brock
Soot n' Cinders
Post by Soot n' Cinders » Mon Feb 27, 2017 6:12 pm
This is true haha. But like I said, there's no telling if the turret throttle was the case for all of the 20 tonners. There's enough variance in what rolled out of Lima to give freelancers a lot of room to play
-Tristan
Projects
Fender
Post by Fender » Mon Feb 27, 2017 6:55 pm
Soot n' Cinders wrote:Its done! Front flue sheet is in and flues are rolled! Ready for a hydro test now, and Im sure my flues will weep a little as I didnt roll them very tight to start
Tristan, did you drill or ream the holes for the tubes? Did you make them on-size, or oversize?
Dan Watson
Soot n' Cinders
Post by Soot n' Cinders » Mon Feb 27, 2017 7:02 pm
The flue holes were water jet cut under size by about 0.01" and then reamed out for a snug slip fit against the flues, so they came out probably 0.005" oversized for clearance and the copper pipe I got was about 2 thou oversized
-Tristan
Projects
Pontiacguy1
Post by Pontiacguy1 » Tue Feb 28, 2017 11:22 am
I always re-ream my front tube sheets after welding if possible. You'll end up getting distortion and some splatter in the tube holes in both front and rear. I also use a small flap-wheel or a piece of stock with a slit in it and some emory cloth wrapped around it to sand the holes out and make them nice and smooth. It also helps to make them a few thou oversize, which you want. You don't want to get a tube about half-way in place and then have it get stuck! I always anneal the ends of each tube. I've heard several say that you don't have to do that if you are rolling them, but I think it makes them roll easier and seat better. I also lightly sand the OD of the tube to remove any scale. I then roll them, and your tube roller should be able to take care of any size differences that you might have. It's especially important that the front tube sheet be slightly larger so that you can get the tubes physically in position.
jlakes85
Post by jlakes85 » Mon Mar 06, 2017 6:35 am
Hi Tristan,
Did you have to do any mechanical running-in on the lathe of the completed engine before it was broken in enough to run successfully on air?
Regards,
John
Soot n' Cinders
Post by Soot n' Cinders » Mon Mar 06, 2017 9:38 am
jlakes85 wrote:Hi Tristan,
Regards,
John
John, I did not run it in on the lathe. Since I had the trucks and driveshafts done before the cylinders, I ran things in by dragging the chassis around the railroad. I used kerosene to clean and lube the bearings during the process, and every couple hundred feet of running I would stop and disassemble the bearings to clean them. When I was happy with how they'd broke in, I cleaned them thoroughly and put some 85W-140 gear oil in them.
Tristan
-Tristan
Projects
Soot n' Cinders
Post by Soot n' Cinders » Mon Mar 06, 2017 5:45 pm
Got the throttle lever made up and working on the quadrant now. Following Jack Bodenman's instructions on making it all but using more of a saw tooth profile on the quadrant so the throttle can be pushed closed without having to release the catch.
-Tristan
Projects
Soot n' Cinders
Post by Soot n' Cinders » Tue Mar 07, 2017 10:14 pm
Got most of the work on the quadrant done today. Just need to drill and tap the hole for the throttle rod and finish the profiling on the other side of the arch.
-Tristan
Projects
Soot n' Cinders
Post by Soot n' Cinders » Thu Mar 09, 2017 10:25 pm
Got the quadrant finished and mounted to the throttle rod. Still need the anchor point and the latch to complete the lever. So far it seems to have a nice smooth motion, but the globe valve does leak a little so I guess it needs lapping. Or just not worry about a little leak, not like thats an uncommon problem!
-Tristan
Projects
05hwy28
Post by 05hwy28 » Fri Jun 16, 2017 6:43 am
Hi Tristan,
We are going with a backhead throttle as well! 8)
Where did you get your pipe for the steam dome and what size / schedule? I am having a hard time finding XXH that is on the prints for a flange; short of spending a day and calling all over town. We are planning on using some 1/2" 516-70 plate for a flat dome cover like you did and just go with a solid piece of pipe also like you did, so I am not sure if we need to go with XXH since that was needed for the flange.
-Mike
