CNW J class Mikado
FLtenwheeler
Re: CNW J class Mikado
Post by FLtenwheeler » Mon Jul 04, 2016 12:48 pm
JohnHudak wrote:
FLtenwheeler wrote:Hi Harold
I use silicon bronze ingots for locomotive parts. I have been using Shapeways "White Strong & Flexible Plastic" for the wax. (LOL) I am having very good luck.
Tim
The white plastic burns out just like wax..? Doesn't shapways print in wax also?
John
Hi John
Yes, the plastic burns out clean, but it does stink. Luckily the work shop is not attached to the house. The Shapeways wax is for small objects and is very costly.
Tim
FLtenwheeler
Post by FLtenwheeler » Mon Jul 04, 2016 1:09 pm
I was able to get some work done on the drivers. The axle hole is bored and reamed to size. Now to cut the keyways.
Tim
kvom
Post by kvom » Fri Jul 08, 2016 6:53 am
Tim
John
The wax is much more expensive than the plastic. Plus, you can make only small parts in wax.
Fender
Post by Fender » Fri Jul 08, 2016 8:34 am
Very interesting, Tim. What temperature do you use to burn out the "lost plastic", and for how long?
Dan Watson
FLtenwheeler
Post by FLtenwheeler » Fri Jul 08, 2016 10:04 am
Hi Dan
I use Ultra Vest Jewelry Investment With Fiberglass and use there standard burnout instructions. So it is 1350F.
Tim
FLtenwheeler
Post by FLtenwheeler » Wed Sep 21, 2016 7:34 pm
I have the driver centers machined and am working on machining the tires. I am going with an 0.008" shrink fit. I am trying to hold a plus or minus 0.0005" on the tire ID.
Tim
FLtenwheeler
Post by FLtenwheeler » Sat May 20, 2017 1:34 pm
Hi All
I just received the Frame Crosstie & Bumper Beam Bracket from the foundry. It turned out great. A printed sand mold was use to produce the casting. I am very happy with the results. How to set it up and machine it. Then I can assemble the side frames.
Tim
Frame, Crosstie & Bumper Beam Bracket
Jerry_H
Post by Jerry_H » Tue May 23, 2017 6:14 pm
It's a work of art, Tim.
Jerry
www.chaski.com
FLtenwheeler
Post by FLtenwheeler » Tue May 23, 2017 7:33 pm
Kimball McGinley
Post by Kimball McGinley » Thu May 25, 2017 2:16 pm
Is that George Washington your change back from a Ben Franklin?
Glenn Brooks
Post by Glenn Brooks » Thu May 25, 2017 6:39 pm
FLtenwheeler wrote:Hi All
Tim
Hi Tim,
This is very interesting! How complicated a process is it to have the foundry create the printed sand mold and make the part?? Is it expensive to create small batches of one off parts, such as 3" scale frame pieces, couplers, etc for a 12" ga loco???
Thanks much
FLtenwheeler
Post by FLtenwheeler » Thu May 25, 2017 7:23 pm
Kimball McGinley wrote:Is that George Washington your change back from a Ben Franklin?
I wish. It was a lot to get this part done. I need to learn how to gate and do the mold setup myself.
Tim
