Erie K5a Pacific
Re: Erie K5a Pacific
Interesting...... I heard you had a neat way of mounting the arch. Can't wait to see it.
Everything looks great so far.
Brian decided to let me machine the tires on the drivers since I have fixtures and the heavy duty lathe to make short work of them. I got them done over the weekend. They will be reassembled and delivered at Cabin Fever. Attached are 2 pics of the drivers.
Also attached is a pic of one of the cylinders mounted on the shaper/drilling fixture. The mounting face is planed first to get the dimension to the bore center correct. I purchased some hardened steel wedges from McMaster to help me get the casting lined up. Using the LE prints and the actual castings; I drew the cylinder mounted on the fixture up in CAD so I knew what dimensions I had to hold the get the angles correct and the bores in proper relation to each other. The fixture was made because I want to use the LE Pacific cylinders for my 2-8-0, too.
The exhaust port is tapped for 9/16-12. The cylinders will be bored and faced in my Reed Prentice lathe on a faceplate with an angle plate. The exhaust port is shown as 1/2" diameter and the 9/16" thread works out perfectly so the casting can be bolted to the angle plate solidly in addition to the 1/4"-20 tapped holes and dowel pin holes. There is also another pair of holes in there that will be tapped for 5/16"-18...they won't be used when bolting the cylinder to the saddle. I want to make sure nothing moves in the lathe. I'll post pics when they get into the lathe.
Andy Pullen
Andy Pullen
Some more pictures of Brian's boiler. Rear Tube Sheet, Door Sheet, Inner Firebox, Dry Pipe to Turret
Is the dry pipe to the turret on a "Tee" to the throttle's dry pipe as well?
Jared Schoenly
Cabin Fever Expo
Model Engineering of all sorts.....
Cabin Fever Expo
Yes it is Jared. It's a 1/2" pipe tee, with a 1/2" pipe dry pipe to the throttle. The dry pipe to the turret is 1/4" pipe, per the customer's request.jschoenly wrote:Is the dry pipe to the turret on a "Tee" to the throttle's dry pipe as well?
Clean. I wasn't sure what was standard practice with that or if it would affect anything on the turret. With 1/2" going front I assume not. Cool, Thanks for the pictures!
Jared Schoenly
Cabin Fever Expo
Cabin Fever Expo
We are trying to finish Brian's boiler for Cabin Fever. Even if it isn't finished I will bring it to display. Here are some pictures from this afternoon. First is the shell on the jackstands. Next is a view of the inside of the outer firebox, showing the through stays and first welding pass. Third is the backhead, then the front tubesheet. Last is the inner firebox.
It looks AWESOME Marty!!! Even if it is not finished I can't wait to see it!!
I have made some progress on the Pacific in the past couple weeks. One weekend I did not work on the Pacific, instead I did some work to my 3/4 inch Mogul, although it is still not ready to be put back together. Here are some pictures.
Machining the front valve gear supports.
The finished pieces mounted on the frame. They were not hard to machine at all, they did take awhile. There was a lot of material to be removed.
Machining the pilot beam.
I don't have any pictures of this, but I did finish the main springs, the rods that go from the springs to the equalizers, and the sway rod bracket that goes between the front frame spreader and the pilot beam. My current goal is to have all the wheels under the chassis and the spring rigging complete by mid May.
Brian
Brian
Here are some pictures from this afternoon. We may not have it finished and tested, but I will be displaying Brian's boiler at Cabin Fever.
Marty,
In the third picture that you posted in your previous post. The stay that is appearing in the top left of the picture looks to be hollow, is that correct, or are my eyes deceiving me? The follow up question would be why is it hollow?
Yes, it is hollow, 3/4" OD and 3/8" ID. It is hollow so the bolt that holds the bracket for the arch can go through it. I don't like welding brackets to the inside of the firebox.redneckalbertan wrote:Marty,
That's a good idea. Is there another hollow stay in the crown sheet to hold up the back of the back of the arch?or do you just use the 2 hollow stays on the bottom of the arch?
