Kozo K-27 build thread
Andypullen
Re: Kozo K-27 build thread
Post by Andypullen » Thu Mar 20, 2014 7:27 am
Looks great, Dale!
Andy Pullen
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30"
JohnHudak
Post by JohnHudak » Thu Mar 20, 2014 12:22 pm
Looking good Dale...!
I'm working on the TT too, hope to have everything finished up this weekend..
John
Michel Richard
Post by Michel Richard » Thu Mar 20, 2014 12:35 pm
John,
There's a hinge of sorts at the bottom of the axle box cover, If I understand correctly. It struck me, last night, which part is it that hinges down, on the prototype: the little piece below the axle, or the big piece that surrounds the whole axle and bearing ?
BTW, well along re-fabricating the axle box covers.
Michel
JohnHudak
Post by JohnHudak » Thu Mar 20, 2014 12:40 pm
I saw that, and I don't know... Maybe Marty can answer that question..?
John
Marty_Knox
Post by Marty_Knox » Thu Mar 20, 2014 5:26 pm
JohnHudak wrote:I saw that, and I don't know... Maybe Marty can answer that question..?
John
It's not a hinge - it's a cotter to retain the cellar.
SilverSanJuan
Post by SilverSanJuan » Thu Mar 20, 2014 7:31 pm
Beautiful work, Dale. What are your drivers made of?
Todd
dalemast
Post by dalemast » Thu Mar 20, 2014 8:33 pm
Todd they are brass . John do you have a measurement on the two hole on the rear frame . Or just guess.Thanks Dale
SilverSanJuan
Post by SilverSanJuan » Thu Mar 20, 2014 10:20 pm
Interesting choice of material. Did you cast them? They sure are pretty.
Todd
dalemast
Post by dalemast » Fri Mar 21, 2014 4:44 am
Todd yes I did .It was a lot of work but I sure learned a lot .Thanks Dale
JohnHudak
Post by JohnHudak » Fri Mar 21, 2014 7:41 am
dalemast wrote:Todd they are brass . John do you have a measurement on the two hole on the rear frame . Or just guess.Thanks Dale
Dale, I haven't put mine in yet, and I'm just going to eyeball them... All they do is hold the bracket for the water lines, so I don't think they're critical... We can always modify the brackets to get them where they need to be if necessary..
John
dalemast
Post by dalemast » Sat Mar 22, 2014 10:40 am
Thanks John That is what I shall do .
Michel Richard
Post by Michel Richard » Sun Mar 23, 2014 4:28 pm
Thought I would add some visual interest to the journal boxes. Made dummy cellars and dummy bearings. I think the round head machine screw at the top will be ok - will not interfere with the roller, but we'll see. May yet add a pin through the bottom of the surround piece and the cellar. Once again, we'll see.
