Kozo K-27 build thread
Pipescs
Re: Kozo K-27 build thread
Post by Pipescs » Thu Dec 04, 2014 9:56 pm
It would also seem that in making all the parts for assembly there would be more chance of mistakes in alignment, where this method ensures the cylinders and valves are aligned.
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Michel Richard
Post by Michel Richard » Sun Sep 06, 2015 7:12 pm
My K-27 running on air.
Not absolutely sure this will work, but here's the link to Youtube
https://www.youtube.com/watch?v=2mo1AEkhmJc
Pipescs
Post by Pipescs » Sun Sep 06, 2015 9:00 pm
Looking Good...
Charlie Pipes
USMC Retired
Current Projects:
Bobber Caboose
Andypullen
Post by Andypullen » Tue Sep 08, 2015 6:37 am
Looks great Michel!
Andy
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30"
JBodenmann
Post by JBodenmann » Tue Sep 08, 2015 10:47 am
Hello My Friends
Great to see all the fine work being done on the K-27 engines. I hope to see them all run someday on the Alcalde & Coalfield high line.
Jack
Loco112
Post by Loco112 » Fri Jan 15, 2016 7:52 pm
Does anyone know what the cylinder castings weigh for these k27s, and what scale is this in?
Anyone know what the weight of the full size locomotives cylinders weigh? What would only one side weigh?
I was offered an 200 lb. melt capacity, coke fired, iron furnace. I'm thinking about which cylinders and in which scales I could cast cylinders for.
Thanks for your help.
Narrow Gauge (Information) Exchange dot Org forum
My Projects:
Davenport 30 ton diesel (SV#101 / D&RGW#50)
C&S 1908 steel & 1905 wood: box, stock, flat, gon
D&RGW wooden freight cars, long & short cabeese
EBT 2-bay hoppers, Conoco #44 tank
DV (K&J) hopper
8"n3 - 3-footers, 8" scale, 24" gauge
Andypullen
Post by Andypullen » Sat Jan 16, 2016 9:13 am
Kozo's cylinders are built up brass/bronze like everything else he has made. There aren't patterns available.
200 pound melt capacity would make a lot of cylinders.
Andy Pullen
PS, I have a pattern for the proper drivers. With the counterweights.
steamingdon
Post by steamingdon » Tue Feb 02, 2016 9:22 am
Hi,
I have been following this Kozo k27 build and this a neat project. I was wondering if anybody has looked @ the boiler design. The thin sheet 2mm and the low boiler pressure, seems odd to me. They talk about making too much steam? Open the fire door, blow the whistle, turn on injector that will take care of too much steam problems. 73 lbs. pretty wet. I would go with 3mm (1/8") for the whole job and 6" copper tube (act. 6 1/8") standard tube, which is readily available. This would eliminate any laps. this would hydro at 150 lbs. 100lbs. working pressure. Now, back to work. :lol:
steamer
dalemast
Post by dalemast » Tue Dec 06, 2016 1:48 pm
Here is my boiler
Marty_Knox
Post by Marty_Knox » Tue Dec 06, 2016 2:02 pm
steamingdon wrote:Hi,
I had correspondence with Kozo on those very issues. He doesn't realize we're a nation of hot rodders, we want everything bigger, better, and faster!
10 Wheeler Rob
Post by 10 Wheeler Rob » Tue Dec 06, 2016 4:56 pm
Very nice looking boiler Marty. After reading Kozo's build plans for it, that is quite an accomplishment to get one built.
Rob
Marty_Knox
Post by Marty_Knox » Tue Dec 06, 2016 7:01 pm
I didn't build that boiler, Dale did.
