Project: N&W class J on 5"gauge
Steamchris
Re: Project: N&W class J on 5"gauge
Post by Steamchris » Mon Nov 12, 2018 12:36 am
Hello Rob,
thank you for your interest. I will post some more picture, no problem. When im back home i will make some more pictures.
I like your project,the J-3's are very good engines.
Another proof for succesful engines, the combination of baker steering G.S.C Frames and the timken runing gear
seems to be a guarantor for that succes.
Would love to see some of your work!
Kind Regards
Chris
The light at the end of the tunnel could be a train ;)
Health and Safety Notice
due to the current economic circumstances , the light at the end of the tunnel
has been switched off !
Steamchris
Post by Steamchris » Tue Nov 20, 2018 5:59 am
Hello,
as requested some more Pictures of the J engine Truck.
Since last posting the spiral springs are mounted, we still waiting for rockers.
All the best
Chris
Steamchris
Post by Steamchris » Fri Nov 30, 2018 6:00 am
Hello friends,
finally thr Rocker for trailing truck arrived yesterday.
I had luck, the guy at water jet company is a RR Fan also ,so i become the parts for free :)
The frame of the truck is sandblasted now, so All parts are ready to be mounted. Some Pictures....
All the best
Chris
Steamchris
Post by Steamchris » Mon Dec 17, 2018 2:47 am
Hello everybody,
After many hours of sheet metal work, the engine truck is now ready. We had to deviate a bit from the original to ensure a screeching distance of 16mm in each direction.
The cylinder drainage could not be done mechanically because the rash of the engine truck is too big for the lever position. Now we have converted these to steam.
The bearing has arrived some days ago and is now mounted on the pivot point.
Some pics of the truck
All the best and merry Christmas to all of you Guys.
Chris
Rob Gardner
Post by Rob Gardner » Thu Jan 03, 2019 1:49 pm
Chris, thank you for posting these very detailed photos of your J's pilot truck. Will be studying them in the near future.
Rob Gardner
JKreider
Post by JKreider » Fri Jan 04, 2019 1:28 am
Chris: As always it is a pleasure to be looking at and following your beautiful work.
Jim Kreider
Steamchris
Post by Steamchris » Mon Jan 07, 2019 3:46 am
Hi Guys,
thank you so much for your words.
After all sheet metal work of the engine truck we started with the trailing truck...some pictutes are attached
All the best
Chris
Asteamhead
Post by Asteamhead » Mon Jan 07, 2019 11:38 am
Hello Chris,
Same laser cut parts as used with my A, different method of making! Here's the missing photo, showing the raw parts.
Much bending and a lot of precise TIG-welding, so many hours of work, yet :roll: !
Carry on!
Asteamhead
A, J Trailer laser parts
Andypullen
Post by Andypullen » Mon Jan 14, 2019 7:23 pm
Amazing work Chris and WD! I love that moment of truth when the air line is connected and the regulator is cracked open and off she goes! I'm looking forward to seeing your beautiful machines in person!
The use of the taper locks on the axles is very interesting. I've used them in industrial applications and they are almost bullet proof. I might have to try them on a locomotive. I'm guessing that you have covers for them so they can't be seen?
Thanks!
Andy
Clausing 10x24, Sheldon 12" shaper, ProtoTrak AGE-2 control cnc on a BP clone, Reed Prentice 14" x 30", Sanford MG 610 surface grinder, Kalamazoo 610 bandsaw.
Steamchris
Post by Steamchris » Mon Jan 14, 2019 11:58 pm
Hey Andy,
we also looking forward to see you in person:)
Yes sure, we will cover the taper locks.
All the best
Chris
Steamchris
Post by Steamchris » Tue Jan 29, 2019 12:37 pm
Hello Guys,
today we finished the work on the trailing truck frame.
Sandblasting was the last step.
Still a lot of work to do for sure, but another big part is ready.
first time under the engine
All the best
Chris
Asteamhead
Post by Asteamhead » Tue Jan 29, 2019 6:38 pm
Hello Chris,
Looking fine, well done! Another important step towards the roll out :)
Asteamhead
Prototype, same as with the J
