CAD conversation to G-Code
Related to all sorts of CAD and CAM tools. Users should post questions, comments, and recommendations with respect to their favorite CAD and CAM tools.
Kelligirl921
Post by Kelligirl921 »
Hello,
Is it possible to convert CAD to G-code? As it turns out, a template of what I produce is a G-Code template and it has gone missing due to a glitch in software. I do have it in CAD format but do not know how to convert, if possible. If not, any idea how or where to get G-Code done in order to re-start production of my parts?
Thank you,
Kelli
Magicniner
Re: CAD conversation to G-Code
Post by Magicniner »
Depending upon part complexity it could be hand coded or you could use CAM.
For someone else to do it for you they would need details of the job material, tooling used, your machine and it's controller to ensure compatible code and the correct feeds & speeds.
RMinMN
Post by RMinMN »
Yes, with some caveats. There are quite a few programs to do this, some with more functionality than others and some which require a specific format of the file to convert. If the part is simple, something like this may suffice.
https://www.youtube.com/watch?v=oNCHRWY9Meo
Post by Bill Shields »
first and foremost, you need to know the target machine / control.
earlgo
Post by earlgo »
Long ago in a (job) far, far away, I was tasked with programming a Cincinnati Milicron T-10 horizontal mill. I was sent to Cincinnati to learn how to program the machine and I was also sent to a Numeridex training class in Chicago to learn how to use their software to draw tool paths and have it converted into G-Code. In the end, after all this training, I discovered that I was much more efficient in writing the G-code than the software was. Perhaps things have progressed since 1984. The upshot was that I wrote the code in Microsoft text editor and it was sent to the machine controller direct where it ran successfully. My point here is that you may be able to write successful code without fancy software.
--earlgo
Earlgo:
your deduction assumes a couple if things
1> simple machines
2> person with pencil in hand understands the machines, manufacturing processes and the codes necessary to create them.
earlgo
Post by earlgo »
Mr. Shields, your points are all very true.
The Cincinnati T-10 was a 10HP horizontal with a 2 pallet changer, 2 45 pocket tool chains with automatic tool changer, an electronic probe and an operator that was really good. Not exactly a simple machine. I guess it probably cannot compare to a home shop machine. My bad. Teledyne Oster used it to make gear boxes and carriages for their pipe threading equipment. The operator loaded the rough casting on the tombstone on a pallet, punched the button, and the pallet rotated into position, the tool changer started and picked the proper tool from the chain and stuck it in the spindle. The spindle fired up, turned on the coolant, and made chips like one can only imagine from a home shop machine. When the cycle was done, the pallet rotated and the finished part came out and the next rough casting went in. It was really cool to see run. Needless to say, I learned a lot on that job.
--earlgo
yes, I am sure you did, as did I on my first NC controlled machine.
There is a lot more to converting lines and arcs to toolpaths, as I hope Kelligirl will begin to realize.
it isn't (yet) like waving a magic wand in Harry Potter Land and making a part appear from a drawing.
earlgo
Post by earlgo »
Ms. Kelligirl: How is the G-code coming along? Hope you are making progress.
A few years back there was a Gcode generator called BOBCAM. I wonder if it is still in use and if it would help.
Good Luck.
--earlgo
BobCAD / CAM is still very much in business...but you need to know what you are doing (or pay $$$) to get the post processors up and running.
heck, you can probably do it from Autodesk Fusion 360 if you want to spend the time...
