Woodinville Shops
Forum rules
Re: Woodinville Shops
Here is the most important field repair of my career as a hobby machinist! My spectacles snapped in two whilst driving down to my boys house to help him do some repairs on his sill and foundation. To far down the high way to go back. Hard to see anything close up when I arrived at my destination.
So I was starting to cobble together some sure to fail temporary fix with electrician tape, when my boy grabbed the broken bits out of my hand, and said “I’ve got a great Idea!” 2 minutes later he crimped a red electrical crimp to both the broken ends and I was able to work the rest of the day AND drive home safely. Ahaha. Perfect. Not pretty, but perfect!
I thought that was the best fix I’ve seen in a long time.
Hey, any port in a storm!
Great fix!
Great fix!
Today, made final preparations for steaming up the Ottaway. 100 last minute things to check and fix. But all ready, I think for my first test run along the new Great Northern Miniature Railaord main line. Very exciting. Tomorrow tells the tale.
https://youtu.be/q9-X5EABQj0
I like the spark arrestor. Especially this year.
Gregg
Very cool, can't wait to see some pictures/video of her steaming along your main line!
Hi Ryan, might have some video tomorrow. Got it fired up today, but injectors weren’t working properly, so couldn’t inject water into the boiler. So only did one short run, then dumped the fire so as not to burn up the crown sheet. Only managed to slime the nice shnny new paint job with copious amounts of steam oil, soot, and rusty exhaust water.
Just cleaned a bunch of pine needles and mineralized crud out of the injectors, and now cleaning them up a bit in white vinegar. So they should be good to go for tomorrow’s continuing shakedown. Hopefully photos to follow.
Curtis, thanks for your comment re: the spark arrestor. Yep, I couldn’t see firing up without one, given the fire weather conditions we are facing now. I am a bit embarrassed by the Lamp Shade design. Gal across the street said she would bring me some Lacy fringe from her sewing table, to hang around the edge. but so,far, it’s functional. Which is the main thing. I’ll probably take the cap off and fit something smaller and less complex after an get the Loco fully in service, and have some spare time.
As FYI, the extra room provided by the design doesn’t seem to interfere with stack exhaust or draft. So that’s a good thing.
Ran the Ottaway on the main line today. Worked on firing technique - keeping the right level of water in the boiler, proper bed of coal, and a head of steam. Mostly successful, except the original check valves for the injectors seem to be starting to fail. They allow back pressure from the boiler to counteract the injectors flow. Steam back jets out the injector overflow line. So tomorrow, off to look for replacement check valves.
Here’s a few pics, after Cinder-Ella got cleaned up after the days steam up.
BTW, the spark arrester seems to be doing its job. Also discovered it cleans up pretty well when hitting it with a blast of water from the hose.
Congratulations! A lot of hard work to get there.
Whew!
Whew!
Russ and Pete, thanks much for the comments. Nice to get the old girl running again.
Alas, checked the Local hardware store today and found they no longer carry carry 3/8” steam rated fittings. The malfunctioning check valves are 68 years old. The next closest possibile vendor is 50 miles away, RT.
Conrad Watne, one of the master machinists in our live steam club is a real artist with a lathe. Makes his own miniature threaded bolts and plumbing fittings for his boiler and all his Locomotive builds. A machinist extraordinaire. “Nothing to it” he says. So inspired by his work ethic, decided to have a go at making these replacement seats in the two malfunctioning check valves. Nothing to it!
Turns out the valve in line with the left side injector uses a flat plastic, maybe neoprene, washer to seal the steam chamber in the valve. The other valve uses a cone shaped seat, turned to 60*, to close the orifice. With the flat seat, I was able to flip the washer over and reinstall the new side on the left side valve. Should be good to go.
Then made a new cone shaped seat for the right hand valve, to insert in place of the original one.
Well, Actually still making the cone shaped seat. As the pictures show, I turned the replacement seat in my old Dalton lathe, using a bit of Silica Bronze left over from a rudder rebuild on my old sailboat. Next, over to the mill tomorrow to shape the paddles on both ends of the seat. Not sure why they are present. I suspect the paddles cause the seats to rotate inside the valves as water flows through. These paddles could possibly prevent an uneven wear pattern from developing in the cone shaped portion of the seat.
For some reason, tiny parts are more intimidating to make than the big stuff.
If anybody knows the reason for designing these seats with four opposing ‘paddles’ on each end, please let me know.
Turned out to be a very interesting process, turning such a tiny part.
Small work requires a different mindset, one that is not usually comfortable for many machinists. I specialized in small, and do not do well with large. For what ever reason, I have the patience for that kind of work (amazing, since I'm not a patient person).Glenn Brooks wrote: ↑Thu Aug 16, 2018 12:14 am For some reason, tiny parts are more intimidating to make than the big stuff.
I'd explore the concept of the diameter of the paddles being a guide (pilot) to keep the valve in proper orientation, yet allowing fluid to travel through the valve when it's open. Does that make sense? Without seeing the entire assembly, I may have the wrong impression.If anybody knows the reason for designing these seats with four opposing ‘paddles’ on each end, please let me know.
Glenn, have you considerd lapping the checks rather than making new parts? You may have to do it even with new to get a good seat in the valve. Just a thought. And nice work on the loco!
