Re: Woodinville Shops
Posted: Mon Oct 16, 2017 8:44 pm
Installed 16 cross straps today to tie the inner set of stringers to the structure. These stringers are 4"x6" set on edge, and lay directly under the rails - taking the weight from the passing train and transmitting through the bents to the foundations. when finished, there will be 4 straps per joint, 20 per bent (with 4 parrellel sets of stringers making up the sub deck). All secured with 1 1/2" X11/4" galvanized lag screws to the stringers, and anchored to the cap timber with 1/4" x 2" lag screws.
These cross straps are exceptionally rigid and strong. They really do a nice job of securing the stringers to the cap timber. Although the stringers are short - around 4' long on average - and only bridge the space between each bents, the resulting structure is exceptionally strong. Nothing moves when all four are secured in place.
I was worried about the joints not being rigid, and planned to add an additional strap across each joint, at the top, to tie each stringer to the next. But no need to use the reinforcing staps. These cross ties lock the timbers solidly in place. There aren't going anywhere!
Now only 350 more lag screws and an additional 64 brackets to finish off the structure. I think I may need a few days off after this wraps up.
