Page 28 of 54
Re: 12" working railroad
Posted: Tue Sep 25, 2018 9:37 pm
by rkcarguy
Thanks Steamin, well I am taking a couple days more rest. I was going to weld the swivel bearing standoffs onto my bolsters, but realized that I'll then need to take the trucks back into work again to weld on the spring seats once the springs come in on Friday, so I'm going to wait and do it all in one shot. I ended up ordering some 1-1/2" free length, 3/4" O.D, 135# springs from Mcmaster-Carr for my riding car. Our laser cutter has caught up and passed the rest of the workload in the shop, so I might see some of my parts get ran this week for the turnout router fixture, switch stand, and maybe my locomotive truck sides as I've finished their drawing and they are ready to cut.
Our programmer/operator is doing some amazing stuff with the laser, he was cutting 3/16" diameter holes in 1/2" plate clean enough that we could gage pin them!
Posted: Thu Sep 27, 2018 10:38 am
by rkcarguy
Well I've got frogs, enough for 10 turnouts:)
What I'm doing is extending the FB rails into the frog from all directions, and then I only had to have these portions laser cut to complete them.
Posted: Thu Oct 04, 2018 12:54 am
by rkcarguy
Today the shop got the turnout router jig laser cut. I got it mounted, and routed the grooves for the rails for the diverging route. I was able to get most of the rails cut and tapped into place as well. This worked absolutely perfect, the gauge is right where I want to be. The only issue is the curved outside rail is putting tension on the whole turnout, and the straight portion of the rails are a little off. I'm planning to pull this out and screw a stringer of 2x6 underneath all the ties if needed.
Just a set of points, weld the rails to the frog, lag down some guard rails and this one is done.
Posted: Tue Oct 09, 2018 10:57 pm
by rkcarguy
I welded up the frog to the rails and got it and the last couple rows of ties miter cut and installed on the turnout.
Posted: Sat Oct 13, 2018 12:42 am
by rkcarguy
Guardrails made and attached. I have a little grinding to do to line up the ends of the rails with the frog but overall it fit pretty close.
Tomorrow I'll cut and start bending some point rails, and get them scribed up for the long miter cut.
Posted: Sat Oct 13, 2018 5:15 pm
by NP317
Lookin' good.
It would be good for longevity to use plastic ties where those parts are screwed down.
Posted: Sun Oct 14, 2018 1:55 am
by rkcarguy
NP, I've clamped those down and through bolted them with big washers on the underside, they won't go anywhere until the ties rot.
I'm hoping with the linseed oil blend and using 5/8 clear ballast that I can re-apply the finish annually and keep the ties in good shape for a long time.
Posted: Mon Oct 15, 2018 11:08 pm
by rkcarguy
I cut some point "rails" and tweaked the curved one in the vice to achieve the proper radius, notched the ties where the point rails will slide back and forth. I'm thinking I'll grind and then weld a flange to these to form an angle, then mill the long tapers so things are more rigid when milling.
Where the points slide back and forth, should I line this with some sort of metal or UHMW? Maybe brass bolts so the heads are just slightly above the top of the wood?
Posted: Tue Oct 16, 2018 12:43 am
by BigDumbDinosaur
I would attach some strips of stainless steel to act as wear pads.
Posted: Tue Oct 16, 2018 11:04 am
by rkcarguy
I can do that, easy enough. I guess I'll line the whole area in the "pockets" even under the solid rails so they are all the same height. It will drop the ties down the thickness of the stainless, but that won't be noticeable.
Posted: Tue Oct 16, 2018 12:00 pm
by Glenn Brooks
Ryan, actually, I would worry more about upsetting the unsupported flat bar with the weight of the engine, as it runs through the switch. This is the most common form of derailment with heavily laden prototypes. The weight of the train pushes the rail sideways, and it (rail) twists and tips enuf to derail. You might consider welding horizontal tabs, say 1” x2” on the bottom of each piece of flat bar. This would solve the wear problem and stabilize the rail.
Alternatively, just use standard Aluminium rail for the moving pieces in these spots. Probably you wouldn’t need more than one or two lengths overall for two switches.
Posted: Tue Oct 16, 2018 12:35 pm
by rkcarguy
Glenn, I'm going to be welding a horizontal bar to the vertical flat bar so its like a heavy angle. I'm planning to stitch weld it with the TIG to control heat. Unfortunately they don't make a 1x1x3/8 angle. I thought about getting some 1-1/2x1-1/2x3/8 and milling the top down to 1", but it's honestly easier and cheaper to weld my own using what I've got. I'd have to buy 20' of the angle and it's heavy and would run about $85, then I'd have to hog 1/2" off of the vertical leg as well.
I just have to grind a bit of a radius on one edge so it matches the curve of the one point rail before I weld it. This will also give me more meat to hold onto when I mill the tapers on the points so I can clamp it securely and hog it off of there with a face mill.
I'll probably use 3/8x1-1/4 flat bar, that's why the pockets are so wide.
I'll need to build one more turnout, and then I'm just another 100 ties away from having enough track to lay the "garbage sub-division" and the siding to the shed and house.
Tomorrow I'll be changing gears though, I'm going to weld my spring perches and bearing brackets onto my riding car trucks so I can get them closer to the point of rolling. Goal is to get the turnout done, and leave it on the bench with the straight section and continue building my locomotive and riding car on this trackage.
