12" gage truck sides
Forum rules
Glenn Brooks
Re: 12" gage truck sides
Post by Glenn Brooks » Mon Dec 18, 2017 8:41 pm
Very nice, I think you nailed it! I like the cutouts, with the contoured edges. Much more prototypical looking than the original Ottaway side frames. Also the sprung bolsters will give a nice ride. Might be worthwhile to review the Tim Bee assembly video to see how he made up the recess/journals for holding the springs in place. Iam thinking there’s a lip on the end of the spring plate to keep them from sliding sideways under load. I can look at that and experiment with machining something once my loco reassembly is finished later this week.
Spent two days getting 4 #12 threaded pins inserted into my little brass handrail stanchions on the boiler - so all the rest of the hardware and plumbing would go back on.
Mike Walsh
Post by Mike Walsh » Mon Dec 18, 2017 9:30 pm
Any reason of going with laser cut over water or plasma cut? Could go with a very rough cut edge with water and get it done faster. Laser would probably be more expensive, I'd think!
rkcarguy
Post by rkcarguy » Mon Dec 18, 2017 11:32 pm
I reviewed a couple truck assembly video's, they popped the springs in using a clamp to compress them, and then with them still compressed, inserted a little "keeper". It's like a piece of flat bar with a groove in it the width of the truck side plate, so it can't move in the pocket once the spring pressure is on it.
I have seen them with and without pockets for the end of the springs to sit in. I think I'd prefer pockets, but I'll have to look into them having drain holes so they don't fill up with water.
rkcarguy
Post by rkcarguy » Mon Dec 18, 2017 11:42 pm
I get a pretty good deal on laser when they have open spots as "infill" work. Also, laser can go to half the hole size of the plate thickness, whereas hi-def plasma and water jet are 1:1 at best. This is important because I can get the bolt holes, grease fitting hole, and grease port hole cut while they are doing the rest, so the parts are pretty much ready to go off the cutting table.
Glenn Brooks
Post by Glenn Brooks » Tue Dec 19, 2017 1:14 am
Yep, I like the pocket idea as well. Wouldn’t take much to mill a slight recession to take the springs. Drill a drain hole through the the bottom to let water out. I could do the mill work in my shop. Wouldn’t take much to do.
rkcarguy
Post by rkcarguy » Tue Dec 19, 2017 1:36 pm
Sounds good. I'm thinking using 3/8x1 or 1-1/4 wide aluminum flat bar, mill a 3/8 wide groove down the bottom, and plunge the proper diameter end-mill in from the top to make the pockets. Could be done to a longer piece, then cut it up in the chop saw.
rkcarguy
Post by rkcarguy » Tue Dec 19, 2017 2:14 pm
Sketch
rkcarguy
Post by rkcarguy » Tue Dec 19, 2017 3:08 pm
Drew this up for my locomotive. I have some channel for the truck sides already machined, but these would look a heck of a lot better.
BigDumbDinosaur
Post by BigDumbDinosaur » Tue Dec 19, 2017 4:05 pm
rkcarguy wrote:Sounds good. I'm thinking using 3/8x1 or 1-1/4 wide aluminum flat bar, mill a 3/8 wide groove down the bottom, and plunge the proper diameter end-mill in from the top to make the pockets. Could be done to a longer piece, then cut it up in the chop saw.
How do you plan to prevent the end of the springs from wallowing out the aluminum?
rkcarguy
Post by rkcarguy » Tue Dec 19, 2017 5:54 pm
They could be made from steel easily enough. I'm not sure it's necessary for my level of use however. Wear will also vary with the loading and spring rates used. A rubber washer could be dropped into each pocket as well. Lots of options there.
BigDumbDinosaur
Post by BigDumbDinosaur » Wed Dec 20, 2017 12:11 am
You do understand that coil springs rotate as they are compressed, eh? If I were doing it and committed to using aluminum, I would insert a round steel shim between the spring end and the aluminum seat.
Glenn Brooks
Post by Glenn Brooks » Wed Dec 20, 2017 12:31 am
Ryan, how many springs do you plan on using each side? Iam thinking maybe 2 or three on each side for the riding cars. Might be just as easy to cut thin sections of pipe and spot weld them in place to seat the springs.
