Rob Roy Valve Rod
Rob Roy Valve Rod
In the re design of the Juliet, I have had to change the design of the valve rod. Stumbling across a picture of Rob Roy valve rods has convinced me they are the way to go. Can anyone supply me a picture of the drawings for this design of valve rod for more inspiration?
3/4" scale LBSC Bantam Cock
3/4" scale B4 project (re-designed LBSC Juliet)
- Stuart T. Harrod -
Re: Rob Roy Valve Rod
I only have the book. The valve rods are double sided of 1/16 bright mild steel. Spacers are 3/16 width.
Holes shown are no 31. Do you need a scan, since you want a Juliet?
Kind regards
Jos Koopmans
Kind regards
Jos Koopmans
- wagonmaker
Is this what you are after?
Hope it helps,
Cheers
Tom
Hope it helps,
Cheers
Tom
Yes it is, thank you Tom
- wagonmaker
You are welcome.
cheers
Tom
cheers
Tom
