Free download D&RGW 3" 7" arch bar truck drawings in 2.5"
I have created these drawings with the help of Jim Schmidt, of the 3" 7" arch bar trucks for the 25 ton, 20 ton and the the caboose truck used by the D&RGW narrow gauge. Go to my web site www.branchlineproducts.com
They look the best if you print them on 11x17 paper. There are 5 drawings.
Hope you enjoy.
Jeff Smith
Hope you enjoy.
Jeff Smith
Re: Free download D&RGW 3" 7" arch bar truck drawings in 2.5
WOW Jeff those are super. Thanks for sharing them with us.
[The web site you listed didn't work so I googled Branchline Products and found you.]
Jim
Jim
Jeff -
I agree with Jim - WOW, FANTASTIC. I was just in the process of converting the trucks to 2.5 scale from the set of stock car plans I got from you. You just made life a lot easier!!! Thanks for sharing the plans.
Chris
Chris
Modeling in 2.5 scale
Very nice of you offer this Jeff! I have both of the freight car books.
Your C-25 looks absolutely fantastic!
Paul
Paul
Thank you. Saves scaling it myself.
Mark Petersen
12" x 36" Logan Lathe
That's it. Thanks Jeff.
- Dick_Morris
Nice! Thanks for sharing.
Does anyone have a technique for bending the eyes on the caboose springs? My best idea is a jig or two of some sort, bend them red, and then heat treat. Mine will be a little easier to bend than the ones in the drawings - they only need to be about .040" thick and .500" wide. I've already proved that the spring stock doesn't bend without annealing, and suspect bending the annealed material cold is an invitation for failure.
Dick,
There is an article in an old LS or Modeltec about how someone made nice looking caboose springs...I'd have to dig thru to find it. Does anyone else recall it?
Found it, Modeltec Dec 1997
Thanks Jeff. By any chance - are you going to be adding these to your production line? Timmy
illigitimi non carborundum
Thanks Jeff, drawings look wonderful. I hope to find the time to build a few sets.
