Acorn-head bolts
Moderators: cbrew, Harold_V
Benjamin Maggi
Acorn-head bolts
Post by Benjamin Maggi »
The plans for my steamer call for making studs from steel rod, threaded on both ends, to secure the steam chest and steam chest cover to the cylinders. I don't like that approach for several reasons. I hate cutting threads, and doing it forty times (20 rods, double ended) is an awful lot of work. So, I plan on using bolts threaded down from the top. Perhaps I will use socket-head cap screws.
But, I thought I would ask if anyone is aware of acorn-head bolts that I could use. I have seen acorn nuts which would look nice on top of the steam chest cover but if I am using bolts they won't work. Has anyone done this before, or seen this?
Thanks.
cbrew
Re: Acorn-head bolts
Post by cbrew »
I have used button head socket cap screws for this very reason. they have a low profile and allows the bronze cover to sit down nice over the chest lid
little giant
Post by little giant »
I cut ss rod to length and threaded the rod into the cylinder and used model hex nuts and left the cover off, looks more prototypical
Benjamin Maggi
cbrew wrote:I have used button head socket cap screws for this very reason. they have a low profile and allows the bronze cover to sit down nice over the chest lid
Could you post a picture of what your cylinders look like? I am having a tough time picturing it.
powderhorn01
Post by powderhorn01 »
Check McMaster-Carr, and look at the allen socket set screws, you might be able to find the length that you need, and use them as studs.
E. Bartlett HTC(SW) USN Ret.
Member Firearms Engravers Guild of America (FEGA)
Nevada Southern Railway (Nevada State Railroad Museum)
Bridgeport Round Ram Mill
11" South Bend/10" Champion Blower & Forge Lathe (Franken Lathe)
12" Sebastian Lathe
everett.bartlett@yahoo.com
cbrew
Post by cbrew »
here are the studs that mcmaster sells
http://www.mcmaster.com/#standard-threaded-rods/=z92agp
caps screws here
http://www.mcmaster.com/#socket-head-cap-screws/=z92cay
since i was going to be hiding the screws anyways, I just used the standard grade 8 cap screw.
the flat tops of the screws make a nice plane for the bronze cover to sit on for a sq fit
kvom
Post by kvom »
What about using threaded rod with the nuts of your choice?
Benjamin Maggi
Thank you all. I didn't know you could purchase the threaded studs and assumed you had to make them yourself. That may change my plans.
Post by SteveM »
kvom wrote:What about using threaded rod with the nuts of your choice?
Silver solder the nuts on.
Might be too much heat for Loctite.
cbrew
Post by cbrew »
Benjamin Maggi wrote:Thank you all. I didn't know you could purchase the threaded studs and assumed you had to make them yourself. That may change my plans.
I will also add this, these are very close to scale 8/32 nuts
http://www.mcmaster.com/#90760a009/=z9l4iw
Kimball McGinley
Post by Kimball McGinley »
You want to be very careful in using a socket head set screw for a stud, as the end with the hex hole has very little tensile strength. A few years ago this was covered in this forum; someone had a boiler check valve blow off under pressure because the nut only holding on the hollowed-out portion of the set screw.
I too just used threaded rod cut to length. Just put on double nuts to run it in to sufficient depth to install the stud.
boomerralph
Post by boomerralph »
You can also get acorn nuts at McMaster Carr all the way down to 0-80
Ralph M. Reese
St. Augustine, FL
Under Construction
LE Pacific
Allen 10 Wheeler
