Train brakes for the little Mogul
Moderators: Harold_V, cbrew
Greg_Lewis
Re: Train brakes for the little Mogul
Post by Greg_Lewis » Mon Aug 29, 2016 10:07 am
Donhost4449 wrote:Happy to help, Ray. I like Clippard, and use their stuff. However, their shipping fee is steep, especially when ordering a single item. I try to group my purchases from them.
I have found that Ebay is a good source for onesies and twosies. The shipping is usually low or folded into the price, and, in contrast to the early days when Ebay had problems with flaky sellers, they've cleaned the place up and I've had nothing but good experiences there for several years. I go for the "buy it now" options as I don't have time to play with the auctions.
Raymbo
Post by Raymbo » Mon Aug 29, 2016 10:25 am
I have been an E-Bay seller of HO, O, O-27, and some other items for many years. I have bought from a few suttlers out there and so far finding what I need easier on Amazon but looking for an air tank there would be a waste of time.
I will have a squiggy at what might be on E-Bay and see what I can do.
RG
Ray Grosser
Former
US Navy Sea Bee, 50s
Journeyman T&D maker, 60s
Builder 1" scale 4-6-2 Little Engines locomotive 63-65
Machinist on the Great Northern RR
Certified welder
Steel erection superintendent
US Army paratrooper, 11SFGP ABN
Taylor 12 string guitar picker
Harley owner and rider
Now that I think of it, I might have made something of myself.
Greg_Lewis
Post by Greg_Lewis » Mon Aug 29, 2016 1:12 pm
You might have luck on Ebay with Chris' suggestion of a paintball tank.
Raymbo
Post by Raymbo » Mon Aug 29, 2016 4:13 pm
Donhost4449 wrote:I decided to use ABS pipe for my brakes on the electric & my LE mogul, max 60 psi. Works well. For those concerned with plastic pipe failure, Clippard offers stainless steel air tanks (link provided).
http://www.clippard.com/part/AVT-32-16
Chris Donhost
Vacaville, CA
Chris, I checked on several different options for an air reservoir, the paint ball gun high pressure canisters are $40 each (Cheapest I found on Extortion Bay) and the Clippard tanks are very nice but also $40 each. I am going to town this week and check on getting some ABS piping, some caps, and build new ones using the plastic. I want them to fit in the carriers I made for our supplement brakes offered by Tom Bee. I checked on using a propane cylinder as noted by several, but I haven't kept one of those in decades. I will hang on to the next one that goes empty and make one out of one of those as well.
Thanks again to everyone for all the help. I learned that all PVC applications for air are not legal in Kentucky for the reason noted by several but ABS is acceptable.
RG
Ray Grosser
Former
Certified welder
rkcarguy
Post by rkcarguy » Wed Dec 06, 2017 12:48 pm
I know this is an old post, but I was searching for info on compressors and tanks and ran across this.
I would not use plastic for any air application, it just gets too "crunchy" over time. The used propane canisters are a good option if you can safely remove the pin and assure it's totally empty. Propane in it's gaseous state builds up alot of pressure so the tanks are built to take it. The paintball canisters do expire after a few years, and are pretty much worthless then. I know our local paintball field charges $7 for an air fill, and for $10 they will sell you a filled tank that only has a few more months left on it before it expires. After it expires it's not allowed on their field. I happen to have 3 of them, so it looks like I have some canisters:)
Another source for buying new tanks with tapped NPT fittings ready to go, is the places that sell the air suspension stuff for the low rider vehicles. They make them in all kinds of different sizes shapes and diameters to fit in various places.
Raymbo
Post by Raymbo » Wed Dec 06, 2017 1:15 pm
Yes, I agree. I did not actually build this tank I bought it from a vendor. Other forms of plastic such as CPVC is better but the metal ones are far superior now that I have learned. If we ever have to change it I will use metal. However, if sunlight UV rays do not get to this PVC tank, it will last a long time and since we are using only 60PSI I am confident it will outlast me.
RG
Ray Grosser
Former
Certified welder
Jawn
Post by Jawn » Wed Dec 06, 2017 10:54 pm
Clippard has a bigger plastic tank as well, AVT-PP-35. This one's fairly inexpensive, has push-connect fittings built in. Rated 125psi.
As to compressors, I wonder how well an automotive air ride compressor would work? I'd expect it to be longer-lasting and quieter than a tire inflator.
johnpenn74
Post by johnpenn74 » Wed Dec 06, 2017 11:20 pm
If you are looking for a economical solution for an out of sight, out of scale air tank, try using an emptied propane bottle. Most have a removable 10-32 thread fitting which can be replaced with appropriate fittings from clippard. The guys at Mill Creek have been doing it for years. The only down side is there is no drain. Could always put one inline though.
JP
John Pennington
Project
2 Mich-Cal Shays
Reading A5a Camelback 0-4-0
USRA 0-6-0
Clishay
4 Western Wheeled Scraper NG Dump Cars <--ALMOST DONE!!!!
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars <--ALMOST DONE!!!!
L&N Caboose
A whole pile of incomplete stuff...
johnpenn74
Post by johnpenn74 » Wed Dec 06, 2017 11:23 pm
Back to the original thread... Your steam brake system on your mogul can be made to work very well. All you need to do is equalize the break beams. Its a hand full of parts that you could do in a day or two. The lap valve is inneffective for steam though. I fixed my brake on my Allen 10 and can gracefully stop 5-6 cars on 2.5% at MCC.
JP
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
L&N Caboose
makinsmoke
Post by makinsmoke » Thu Dec 07, 2017 9:33 am
I believe Bill S has posted or offered drawings for
the equalized brake gear on the Allen ten wheeler.
Other Allen locos should be easy to do.
Post by Bill Shields » Thu Dec 07, 2017 11:05 am
You can find them here for my 2-8-0
WWW.MEHRS.COM/misc.html
adding or subtracting an axle is easy.
Greg_Lewis
Post by Greg_Lewis » Thu Dec 07, 2017 11:19 am
I wrote up the equalized brakes for the Allen 10-wheeler and Mogul many years ago. If anyone wants a copy, just email me at gregl@mail.fresnostate.edu and I'll send along the pix and drawings.
