SRRL #23 First Run in Maryland
- SZuiderveen
Re: SRRL #23 First Run in Maryland
I think you will have to go to to Reeves or E. & J. Winter to get Lucky 7 drawings. I don't think anyone in the U. S. maintained the publication rights after Power Model went away.
Steve Z.
Steve Z.
Could you ask your friend if he would be able to make copies of the drawings he used?
Or if you are able too, if you are able to put us in contact that would be very helpful.
- SZuiderveen
John built the running gear to Roll Model drawings. The remainder was done from the prototype drawings in Two Foot Cyclopedia by William Jensen, Jr. The tender is mostly "nuts on." The loco is selectively compressed shorter to fit the running gear, but has a larger diameter boiler than RMI and a scale cab. I'll have some construction photos to post soon.
Man it'll be a chore getting a hold of the cyclopedia, i would like to see the pictures though its a lovely engine.
Yes definitely.seadevil10 wrote:Thank you Harlock for the quick response. I hope you are able to fine out about the drawings. So the castings and parts for the 3.5in scale will be up by years end maybe?
- SZuiderveen
Inspiration from the wall in John' s office
Not a chore at all to get the cyclopedia for #23, scroll down about half way:
http://www.maine2footquarterly.com/books.htm
- SZuiderveen
OK, by request, here is a short summary of the build of the #23 written by John Tokar, plus a selection of build photos. If the Admins feel this should go in the Build Log, please move, but as of now, I guess it would be a built log!
(But you oughta look at all of the cool cars from the home page, too!)
Regards,
A more direct link: http://www.vintagerestorationsltd.com/trains.htmlJohn Tokar wrote:
A Brief Summary
This locomotive is 3 ¾” scale and weighs about 2000 pounds (a fork lift comes in handy!). The original frames and casting were manufactured by RMI and purchased in 2007 through a private owner via Discover Live Steam. The frames started out as a 2-6-0 but I decided to add an extension (as they did in full size practice!) and make it a 2-6-2. It employs RMI running gear and brakes as well.
This locomotive was not intended to be an exact, scaled down reproduction but is based on SRRL Baldwin #23. I used the Baldwin Locomotive Works erection drawings (public domain) for SRRL #23 to fabricate my engine with the intent to make it more prototypical and easy to operate.
The boiler (many thanks to Marty Knox!) is coal fired and has an OD of 12.750, which allows for a 14" smoke box (front castings from Steve Alley) and is fully jacketed. It has engine and tender air brakes powered by a steam-driven air compressor (castings from Mike Veneisa and machine work by Steve Alley). It has a steam-driven dynamo (6 VDC at 4 amps) for engine and tender lights.
The backhead is my own design; the cab was purchased and is a rare find that replicates the full size engine perfectly! I owe a debt of gratitude to Andy Pullen for his excellent machining skills on the engine’s steam chest, wheels and other castings.
The tender is completely scratch-built by me and is constructed from 11 gauge HRS. It is based on Baldwin’s #23 tender, including the brake gear. The water tank is in the rear. It is sealed with Rhino bed liner and holds about 25 gallons. The side legs contain electronics for a series/parallel 6 and 12 volt DC electric system that has controls in a flip-up door in the right leg. It supplies power to a boiler feed water pump, a backup air compressor and later, a back-up vacuum pump for the train brakes.
The trucks are from Ken Schroeder and are beautiful reproductions of the ones used on #23!
Most importantly, I owe a world of thanks to Steve Zuiderveen for his support, consulting/inspiration and his time spent with me working on this project!
Additional construction photos can be viewed on my company website http://www.vintagerestorationsltd.com under large scale locomotives.
Regards,
- SZuiderveen
And here are a few more photos from John:
Regards,
Regards,
- SZuiderveen
Last set for now:
Regards,
Regards,
- SZuiderveen
I had an original copy of the Jensen book, which John used extensively. When M2FQ came out with their copy, John bought one. An exceedingly poor reproduction job of a Jensen original!Sandiapaul wrote:Not a chore at all to get the cyclopedia for #23, scroll down about half way:
Regards,
