Eccentric Engineer: New supplier. Injectors and more!
Re: Eccentric Engineer: New supplier. Injectors and more!
Anthony, those are gorgeous! They reflect a lot of work and detail. I have an 18" gauge locomotive, about 4" to 5" scale, anything in the works for this size?
John
John
- AnthonyDuarte
Thank you for the kind words, John! Countless hours have gone into these projects so far, but I've loved every minute of it. I have thought about making a few things for the grand scales. Can't make any promises just yet.
- johnpenn74
Anthony,
I have a few narrow gauge projects on the list and look forward to buying your injectors in the future.
I would like to give some feed back and make a suggestion. Would you please consider fabricating the injector body with 1/8 or 1/6 npt 5/16 mtpt thread connections to the body? This would allow a universal or compression coupling to be attached directly and easily.
I have removed all of the soldered connections on the plumbing and have made the transition to MTPT, NPT and compression fittings so that all plumbing on my engine is mechanical in nature. - similar to the prototype practice.
JP
JP
John Pennington
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
Project
2 Mich-Cal Shays
USRA 0-6-0
Clishay
N&W 4-8-2
ICM 2-10-2
4 Modern Stake Cars
L&N Caboose
I am interested in your standard injector for 1.5 scale. Please notify me when you have some for sale and the operating pressure. My boiler pressure is 135. You can notify me at my email address tomstamey@sbcglobal.net
Thank you
Tom Stamey
Thank you
Tom Stamey
- AnthonyDuarte
Thanks Tom, I've taken note of it!
I am interested in your standard injector 1.5 scale looking for two to Purchase my working pressure is 125.
please let me know when you have them available.
Please contact me @ jhansen@mtac.com
Thank You
John Hansen
Thank You
John Hansen
- AnthonyDuarte
Thanks John! I have you down.
What material will you use to turn the cones from?
Thank you,
Steve Kuhn
Thank you,
Steve Kuhn
- AnthonyDuarte
Steve,
Cones are machined from brass bar stock.
-Anthony
-Anthony
