Allen Models making changes.
cbrew
Re: Allen Models making changes.
Post by cbrew » Fri Apr 21, 2017 12:41 pm
In my area. Water jet carries about a three fold cost increase over laser. At lease it did when I was shopping around. It's not worth it for anything I have built to date
Post by NP317 » Sat Apr 22, 2017 10:16 am
cbrew wrote:In my area. Water jet carries about a three fold cost increase over laser. At lease it did when I was shopping around. It's not worth it for anything I have built to date
Thanks for that info, Chris.
I remember that you had your coach parts laser cut. Seems like the better solution these days, at least for thinner metals.
Nice to see you posting again. 'Thought a rock fell on you for a while.
~Russ
John_S
Post by John_S » Sun Apr 23, 2017 6:26 pm
NP317 wrote:
rwmorris wrote:I'm huge fan of water-jet parts... The rods are a perfect candidate for this process.
I would expect water-jet to cost more that laser cut. Anyone have info on relative costs?
The water-jet I had in my University shop had high consumable and cleaning expenses.
But they surely work wonders.
I work with water jet and laser shops every single day (for my day job) and it depends on what you're having them cut. Sometimes water jet is more, sometimes laser is more. Material, quantity, shop schedule, etc., all play a role.
i.e. if a water jet shop already has a job lined up with the same material they can add your parts onto it (one setup) and cut them cheaper than if they have to do your job on its own.
If you have a choice and are flexible, I'd go with water jet. No edge hardening.
rwmorris
Post by rwmorris » Sun Apr 23, 2017 6:44 pm
I use waterjet a little more because I can swing deals with the owner which helps on the cost. I did however just run a job for a work item and laser won out by about 8-10% reduction in cost over my preferred method.
Here's the new frames and side rods for my version of the Allen American. Pretty slick and they only need minor machine work to finish up.
//uploads.tapatalk-cdn.com/201704 ... 0a7505.jpg
-Robert M.
cbrew
Post by cbrew » Tue Apr 25, 2017 2:09 pm
~Russ
yup, still kicking, currently doing a full rebuild on the ole american, times to bring her back too her full glory :)
the ten wheeler will be then go through a transformation ;)
Post by NP317 » Tue Apr 25, 2017 4:05 pm
Chris Brew said: "the ten wheeler will be then go through a transformation "
This I gotta see!!
