Diesel-Electric Models
Andrew Pugh
Re: Diesel-Electric Models
Post by Andrew Pugh » Fri Apr 21, 2017 12:24 pm
A true scale 567 or 645 (2-stroke, running on diesel) might be a stretch, but a multi-cylinder diesel should be doable...there are a few (and I mean a few) videos of small scale compression ignition working diesel engines (running on diesel, not nitromethane, and no gloplugs) on youtube.
It wouldn't be beyond the ability of some builders to make a working 16cyl diesel, but probably quite a challenge to make it work as a 2-stroke. Someone needs to commission Find Hansen. :-)
BigDumbDinosaur
Post by BigDumbDinosaur » Fri Apr 21, 2017 2:13 pm
Andrew Pugh wrote:A true scale 567 or 645 (2-stroke, running on diesel) might be a stretch, but a multi-cylinder diesel should be doable...there are a few (and I mean a few) videos of small scale compression ignition working diesel engines (running on diesel, not nitromethane, and no gloplugs) on youtube.
I did kick around the idea of converting the Briggs V-twin to Diesel, as the basic engine has a pretty stout lower end and is well balanced. However, with only four bolts attaching each cylinder head to the block I anticipate intractable head gasket problems will arise with the necessarily high compression ratio. Also, the Briggs is an oversquare design, which typically doesn't work well with compression ignition.
As for building a scale 567, I'm planning on tackling that project in my next lifetime. :D
FLSTEAM
Post by FLSTEAM » Fri Apr 21, 2017 2:39 pm
John Boots has an F7 ABBA powered with a V twin driving two Lease Nevell alternators. The alternators charge the battery set. Not sure how many traction motors there are but the engine can run all day pulling heavy loads. I know at least two of the units are powered.
John B.
http://www.ngshay.com/
Shay drawings and castings
Marty_Knox
Post by Marty_Knox » Fri Apr 21, 2017 2:42 pm
I always thought an ALCO 539 would be a good engine to build for a scale Diesel. Inline 6 cylinder, they remind me of an older Chevy 'Stovebolt Six'. With a 12 1/2" bore by 13" stroke I think it would be workable - in 1 1/2" scale it works out to a 1 9/16" bore with 1 5/8" stroke. They were available Turbocharged or naturally aspirated. Oh, and they are a 4 cycle engine.
LVRR2095
Post by LVRR2095 » Fri Apr 21, 2017 4:37 pm
I used to run a ride on size ALCO diesel back a little over 40 years ago.
Until the turbos got up to speed they made a lot of smoke!
Keith
LV RFofE Taylor Testing Engineer's Seat of LV #415 (Alco C-420) at Oak Island Enginehouse in Newark, NJ - August 06, 1974.jpg
ALCO C-420
Cary Stewart
Post by Cary Stewart » Fri Apr 21, 2017 5:14 pm
RMI models makes a 2 1/2" scale Diesel-hydraulic model of the GE 70 ton engine like the SP Narrow Gage X-1. Several have run at LALS of over the past few years. I wonder if it could be produced with a generator and electric motors? Yes it has a Diesel engine but is VERY quiet.
Cary
RONALD
Post by RONALD » Fri Apr 21, 2017 7:16 pm
Great discussion, but you guys are neglecting the physics of Scaling Factor!
Thermodynamics does not scale down the way you would like, otherwise every HO gauger would be running a real steaming "Big Boy" on his 4'x8' layout.
Reducing an EMD or any other full size diesel to 1/8th full size may make a great looking small model that will work on air, but once you try burning fuel the Thermodynamics of Scaling Factor has its effect.
Smokey N Steamer
Post by Smokey N Steamer » Fri Apr 21, 2017 11:06 pm
I agree. Finding a compromise between authenticity and practicality can be tricky unless you push the right buttons.
I too have dabbled with the idea of a true diesel-electric or gas-electric, and I understand that it will take a lot of engineering to get it to run right.
At least I got the prime mover issue solved, thanks to Kubota's super-mini line of small diesel engines. For a cab unit, like an F-Unit, E-Unit or ALCO PA, their D902-E4B is just small enough to fit inside the shell. For you hood unit guys, I believe if you mount a Z482-E4B so that its output shaft is oriented laterally, it should work out. Fitting the fuel tank, cooling system and exhaust pipes, though, is up to you!
Just thought I'd chime in on my view of the idea.
BigDumbDinosaur
Post by BigDumbDinosaur » Sat Apr 22, 2017 11:17 pm
Smokey N Steamer wrote:For a cab unit, like an F-Unit, E-Unit or ALCO PA, their D902-E4B is just small enough to fit inside the shell.
Did you look at the outline drawing for that powerplant? It's over 21 inches tall, much too large to fit a 1.5" scale loco.
DanSmo
Post by DanSmo » Sun Apr 23, 2017 4:17 am
Here at the Diamond Valley Railway we have a number of true diesel electric and petrol electric locomotives. They operate just as their full size counterparts with the throttle controlling the power. I can provide more specifics if anyone is interested. Here's a brief overview of a few:
T415 has a genuine AC traction.
A small 3cyl Kubota diesel (900cc I believe) drives a 3phase 415V alternator which in turn drives two 1.6kw traction motors, one on each truck, via a VFD. The loco is also Radio Controlled. Built by a very talented gentleman. (photo credit Sam Daly)
CL9 has a Toyota 4y motor driving a 400A 28V generator which in turn drives two 2.4kw 24VDC forklift motors for traction.
Milwaukee Road is loosely based on an FP45. It has a Datsun 120B motor driving a 36V 200A generator coupled to a pair of Dodge North East starter/generators for traction.
I just don't understand pronouncing solder as "sodder"... where did the L go?
Andrew Pugh
Post by Andrew Pugh » Sun Apr 23, 2017 9:58 am
Hello Dan, what scale are those locomotives built to?
I've seen a few locomotives from Austrailia at Train Mountain, and they were a fair bit larger than e 1:7.5 and 1:8 locomotives typical in North America for use on 7.25" and 7.5" gauge track. You could even sit in the cab on some of them.
AP
Smokey N Steamer
Post by Smokey N Steamer » Sun Apr 23, 2017 4:09 pm
Well, you could cut a hole in the floor of the unit to make it fit...that's what I had in mind.
